How ? Engine cover removal
Old Dec 27, 2013 | 10:13 PM
Thahomeboyb's Avatar
I have a 2002 lancer I want to remove the engine cover so I can properly clean it and paint it . I unscrew and try to pry it the front lifts up a little but it just won't come off.
Old Dec 28, 2013 | 05:24 AM
eusgen's Avatar
Wait... what?! you are prying on the valve cover (rocker cover in full service manual)? If this is what you are talking about there are 6 bolts holding it down and they are torqued very low, like barely hand tight (especially for a stronger fella). You shouldn't need a pry bar to get this item off.
Old Dec 28, 2013 | 08:50 AM
I wasn't using a pry bar . I was using a screw driver to open it up so I can just take it off . I was very gentle when trying to open it.
But is don't see a 6th screw . There's 3 in the front 2 in the back .
Old Dec 30, 2013 | 01:33 PM
Green_Bandit's Avatar
There are 6. Use your eyes man. Then once all 6 are out use your hands and arms to pull the valve cover off.
And I sure hope you have new gaskets.
Old Dec 30, 2013 | 03:58 PM
SilentCool's Avatar
Yeah man, this definitely shouldn't take so much effort. As mentioned previously you should definitely replace that gasket while you're at it. Let us know how you make out.
Old Jan 1, 2014 | 06:38 PM
Ok will do lol .
Old Jan 8, 2014 | 12:09 PM
leash3988's Avatar
It should come right off. I'm a chic and I have never had a problem. Definitely replace the gasket!
Old Jan 8, 2014 | 12:19 PM
Yup figured out how to take it of . Gunna paint it gold . How much is a new gasket ?
lasmariaspr
Apr 9, 2015 11:15 AM
akqowns
Jul 16, 2014 08:36 AM
snafufx
May 26, 2013 11:25 PM
Tpatterson
Dec 15, 2011 04:57 PM
Jush
Dec 11, 2011 03:25 PM
