CAMS, we need them
Old Apr 14, 2004 | 08:19 PM
hardcoretuner's Avatar
CAMS, we need them
ROCK! any plans to make some cams for our car?? anyone else any plans. has any one actually gotten the cams to work that rpw has?? i know some people have them but i have heard bad things.
Old Apr 15, 2004 | 09:31 PM
res0pfbp's Avatar
yea that would be nice
Old Apr 15, 2004 | 10:14 PM
omarboy25's Avatar
i actually pickep up the vernier cam gear and turbo camshaft with retainers etc we will see the outcome also did rods have pistons will keep you posted
Old Apr 15, 2004 | 10:22 PM
.L.'s Avatar
.L.
omarboy25 what ever happened with adfx? are they offering a turbo kit for the lancer yet? hows your car doing?
Old Apr 15, 2004 | 10:42 PM
Viciouz's Avatar
omar where did u get the turbo camshaft n will that werk with superchargers... how much were they
Old Apr 15, 2004 | 11:23 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Re: CAMS, we need them
I thought Uranium9v got his cam to work perfectly and even reported gas mileage as high as 40 mpg with it!!!
Old Apr 15, 2004 | 11:42 PM
HeavensMist's Avatar
Here are RPW's camshafts: HERE
-The standard grind on average is - TBA
-Stage 1 grind is for all standard / lightly modified vehicles with or without ECU modifications (not necessary)
-Stage 2 grind is for improved mid range / top end at the expense of slight loss of torque at low rpm. Valve Springs required, Vernier Cam gear optional.
-Stage 3 grind is for improved upper mid range / top end at the expense of loss of torque at low rpm levels. Valve Springs & Vernier Cam gear required.
-Stage 4 + grinds available for racing purposes only. Valve Springs required & Vernier Cam Gear Required.
-Above grinds are also available in a turbo / supercharger format to improve the efficiency of such system.
Old Apr 17, 2004 | 02:12 PM
someone track down uranaium and see if he did get his to work right
Old Apr 17, 2004 | 03:37 PM
ghostrider's Avatar
He had an entire thread dedicated to the install and outcome and if I remember right, it was about $400+ to install which was the only downside to the whole event. The gains were good and mileage actually went up.
Old Apr 17, 2004 | 04:24 PM
Viciouz's Avatar
i tried running a search... but couldn't find them...
Old Apr 19, 2004 | 02:07 PM
like he said. i tried doing a search but couldn't find it. someone post it or track him down!!!
Old Apr 19, 2004 | 02:26 PM
rhyzin's Avatar
first post with issues:
https://www.evolutionm.net/forums/sh...hlight=rpw+cam
his review:
what were you guys searching for? i just put in "rpw cam" and looked for uranium9v's name in the thread starter. later in the first thread the rich condition was fixed when U9V found out the dealership that installed the cam forgot to hook the MAS back up. it was running in limp mode the whole time.
Old Apr 19, 2004 | 10:47 PM
Viciouz's Avatar
wow read all the info in those posts... and all i have to say is taht imma get the RPW 1.5 cam gear set... jus wondering tho... do i need an afc or safc if i have the rrm pb?
Old Apr 20, 2004 | 01:43 AM
skiidaho1978's Avatar
So if i plan on going turbo later what cam should i get and do i NEED an afc so my car will run and get decent milage and idle correctly and things like that I really dont know much about it? Anyone who knows please fill me in on what i need to order and get installed Im looking to do this fairly son probably next month. SO i want the right cam and AFC if i need it with my turbo which il get from RRM or RPW depending. Any help is greatly appreciated thank you.
Old Apr 20, 2004 | 02:17 AM
rhyzin's Avatar
NA cam doesn't need anything. safc does help optimize A/F ratios but is not necessary.
as far as turbo cam, i don't know but would think that it would need more than just an safc. rpw turbo kit requires injector upgrades as RRM kit does not. i wouldn't count on compatibility until someone tries it.
an email from RPW said that an NA cam does not make good power with a turbo. if you're NA now and plan on going turbo later, the turbo cam on an NA would give better low end torque and midrange while being a little lazy on the top end. so it all depends.
