reset ecm?
Old Sep 13, 2002 | 04:21 AM
agsmooth84's Avatar
reset ecm?
how do you reset your ecm or whatever the computer thing is called? and should i do this since i have a catback and intake, i heard i should, thanks
Old Sep 13, 2002 | 04:40 AM
akademiks's Avatar
ecu? easy, just unplug it for a little, then re-connect it...i believe it's located in front of the passenger side, but you're gonna have to remove the carpeting and stuff like that...i'd check a service manual to be sure first
Old Sep 13, 2002 | 07:59 AM
pjal84's Avatar
It's behind the glove box. You don't need to dig around for anything. Disconnect the battery for X number of minutes (10-15'ish) and that'll clear it.
Old Sep 13, 2002 | 08:20 AM
agsmooth84's Avatar
thanks guys heres a for ya
Old Sep 13, 2002 | 09:07 AM
Boni's Avatar
Old Sep 13, 2002 | 10:50 AM
pinoyesv6's Avatar
you don't really have to reset it just drive with it on. your ecm will see u have new changes adjust and the CES light will go off
Old Sep 13, 2002 | 07:11 PM
Unamed's Avatar
Mine opposed to changing and turning the SES light off changed and turned it on.
Old Sep 13, 2002 | 07:22 PM
uranium9v's Avatar
mine changed and threw a cel too...
Old Sep 14, 2002 | 04:00 AM
bahamut's Avatar
Actually, disconnect the battery for about 3-5 mins, and the ecu should relearn itself. If you have a manual, it will stumlble or stall within the first 40 miles before a basic perimeter of your driving style will be learned.
Old Sep 15, 2002 | 02:01 AM
el turbo's Avatar
does anybody know if the computer "throws codes" with an led. or is there comething that you need to plug into it to read the codes or see if somethings messed up. i know honda ecu's have the blinking led...
Dstorm7
Lancer Troubleshooting
Sep 25, 2016 04:43 PM
Raceghost
Aug 3, 2016 09:01 AM
Ksay3
For Sale - Part Outs
Feb 23, 2016 01:12 AM
302Squill
Mid-Atlantic Region
Aug 21, 2015 09:22 PM
chaquita
Feb 25, 2004 05:26 PM
