ROAD/RACE- Anyone interested in FORGED N/A PISTONS?
Old Apr 26, 2005 | 05:58 PM
  #481
Boeturbolancer's Avatar
what are you waiting for
Gotta be over a weekend though
Old Apr 26, 2005 | 06:24 PM
  #482
GreenPsycho's Avatar
Originally Posted by 03RallyLancer
i could fly you out and set you up in a hotel for 500 and still beat out my estimates
psssh, screw that, get a boe-size cage and ship him ground
Old Apr 26, 2005 | 08:25 PM
  #483
ROCK's Avatar
I think these are gone again. We will see.
ROAD/RACE
Old Apr 27, 2005 | 01:32 AM
  #484
gregivq's Avatar
I got a gasket for $60.00, bolts $58.00 (15 bolts, need only 12), water pump $45.00, timing belt $35.00 .
Install is very cheap thanks to Omarboy25 who gave me a number to his friend
Old Apr 27, 2005 | 01:52 PM
  #485
Blacksheepdj's Avatar
Wow. I'm going to give it a shot reusing the head bolts and gasket, after discussing the matter with Engineerboy.
I'm glad to hear the timing belt is cheap, though.
Boe - visiting Cleveland anytime soon?
Old Apr 27, 2005 | 04:07 PM
  #486
gregivq's Avatar
I really don't think you can reuse the bolts and the gasket!!!
From what I have been told it's impossible!
Correct me if I am wrong.
Old Apr 27, 2005 | 04:10 PM
  #487
Alchemist's Avatar
you're wrong. I've reused both and plan to reuse them again when I install my cam and new ported head (different from the ported head that's on the car now) I may even be finished tonight- I put in 2 hours last night and took the IM and header off and drained the fluids. Tonight I'll have closer to 5 and can probably get most of the major stuff done, if not finish.
Old Apr 27, 2005 | 04:25 PM
  #488
you reused your headgaskets?? That can't be right!
Headbolts are fine to reuse.
Old Apr 27, 2005 | 04:36 PM
  #489
Alchemist's Avatar
They're metal- why wouldn't I reuse them? Obviously it hasn't been a problem.... and if it should become a problem, I'll just reuse the one that came with my spare engine. Compression is good and I haven't used up an inordinate amount of oil (except for one day for autocross school I was on the track for about 4 hours at or near redline in 2nd. Then I ate about 1/2 qt)
If I get to the part where I torque down the headbolts and there's slop or another issue, then sure, I'll use a different gasket. I'm not gonna spend $60 everytime I swap a head- that's just bad sense. Maybe next time
Old Apr 27, 2005 | 04:39 PM
  #490
From many years of experience I can say i would never reuse a head gasket. If it's working out fine for you then go for it...
For all others i strongly disagree with reusing the headgasket... They ARE NOT ment to be reusible!
Old Apr 27, 2005 | 04:40 PM
  #491
Especially if you're boosting... just ask any reputable shop.
If you switch to copper gaskets then you can reuse them a few times... but they are totally different.
Old Apr 27, 2005 | 04:50 PM
  #492
Alchemist's Avatar
Boosting is a different issue- in that case it's imperative that you use a new gasket. No argument there.
If, when I take the head itself off again, the gasket doesn't look 100%, then it's time for a new one. If, when I go to tighten the bolts, they feel sloppy or don't want to sit right on the 90deg angles, then it's time for a new one.
Am I tempting fate? Somewhat. Am I concerned? No, because I can do the whole swap in less than 11 hours (and that last time it took 11 hours because I had the exhaust valves on the intake side and had to completely disassemble and reassemble the head before install- this time should be less than 8 total) and it's free for me to do it. If I was doing this for someone else, I'd certainly NOT do it without them showing up with gaskets- I'm not going to do this twice and not get paid twice
I appreciate your concern.
Old Apr 28, 2005 | 06:42 AM
  #493
2002lancer-OZ's Avatar
Originally Posted by Blacksheepdj
Hmmm - there were 5 sets.
Greg's and mine are chillin' and awaiting install.
Boe had a set, sold his engine, and is buying another.
Where did the 5th go?
I have a set that I bought off of tweak3d. Havent had them installed yet but Im about to have them done. It is going to cost me $300 plus a head gasket I did have one guy who said he would do it for $100 and a case of beer but Im not to sure if that is a good idea Anyways, does anyone have them installed already? If anyone has, how is the difference in power? Is it noticeable?
Old Apr 28, 2005 | 08:22 AM
  #494
ROCK's Avatar
Make sure you give him the case of Beer after he finishes!
ROAD/RACE
Old Apr 28, 2005 | 04:32 PM
  #495
i had them already and can tell you it's definately noticeable... this time i will be using the emanage to dyno tune so i'll post numbers. Give me a few months to get it all done and dialed in.
