Installing my Kamikaze header this week....
^ ya lift up your passenger side carpet uplug the hole where the wires are going into and it should have ehoung slack for you to turn it around...ill be doing this soon also
Originally Posted by SIMSSEGA
i dont think you do. If you pull the plug through the hole under the car you should have plenty of room. You'll know what im talkin about when you get under there.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
02 sensor
you have to remove the center console lift the carpet alittle on the passanger side. you need to add about 8 inches of wire. there is not enough there. and if you do happen to stretch it enough the wires will rip because it needs a little slack to move with the exaust. If you need help albanks shoot me a pm..
ParanoidBebop
Dec 20, 2012 04:47 PM
