Aftermarket cruise control anyone?
yeah the throttle body is set-up quite differently, a few more screws, added throttle idle speed (w/ CC)...i don't know the signifigance of this part though since w/CC it has both throttle idle and speed idle adjustment screws...there is also the obvious steering assembly you would need to set CC...and like greenpsycho said there is a vacuum line that runs in on the top of the TB...when the rain lets up outside i will go figure out where exactly it runs and try to post pictures for you.
i say if you really want it, source down an oz in a junkyard and get all the parts you need
of course, i'm sure installing it will be MUCH harder than what were making it out to be, so its probably not for the squeemish
honestly, it's probably not worth the hassle either to remove or install cruise control...to much time to get the parts let alone install them...with the time and money you spend on CC you could probably have gotten yourself a new mod or a nice dinner hahaha
Originally Posted by HobieKopek
Not to go off topic, but what's the bore on the 1g DSM TB, and is it a direct bolt-on?
That new mod isn't going to make him feel better when he can't move his leg on the way from Cleveland to Cincy.
The dealer gave me a number for a guy that installs them for $295 out the door. If I decide to do it I will go that route. Dealer and installer say it's the same unit installed at the factory.
smokem22
12
Aug 2, 2021 06:10 PM
Blitzboyii
Oct 29, 2014 05:15 PM
chase2000gt
Jul 5, 2005 05:56 PM
2002, 2003, aftermarket, control, cruise, install, installation, installing, lancer, louis, mitsubishi, north, olmsted, st, tucson
