Just got the NEW ///RRM Crank pulley installed!
Old Dec 19, 2005 | 10:33 AM
  #196
mitsulancerrace's Avatar
everything was fine with it, my teacher works at a shop and has a life of fixing cars n restoring cars, he said they both r fine
Old Dec 19, 2005 | 03:43 PM
  #197
Blacksheepdj's Avatar
Originally Posted by comatose721
i've been having an issue with the alternator belt slipping since the install...originally it was to tight and now it won't hold tension..the belt is on it's way out though...check yours and make sure there are no small cracks, fraying, etc. a bad belt will make noise like that.
You could have overtightened it. I've done that. There's so much stress on the belt, it can't grip.
Old Dec 19, 2005 | 06:07 PM
  #198
ROCK's Avatar
Correct Comatose!
ROAD/RACE
Old Dec 20, 2005 | 07:35 AM
  #199
comatose721's Avatar
i'm going to buy a new alternator belt today. once finals are over this week i'll put it in and let you guys know if that solved the problem. i'm 99% sure that it will.
Old Dec 22, 2005 | 07:26 AM
  #200
sthiewes's Avatar
i chip in shipping charges i want you to have it hehe
Mark,
Looks like I will be getting that pulley!!! Bonus from work So maybe I'll just treat myself to a pulley and another RRM toy . Not sure what though, maybe: Bored Throttle Body or Ported IM or Bored Fuel Rail or Springs ...Too much to choose from.
Old Dec 22, 2005 | 08:42 AM
  #201
ROCK's Avatar
Good for you!
ROAD/RACE
Old Dec 22, 2005 | 11:27 AM
  #202
let us know what you order! then i will make my small contribution to ship your pulley.
by the way, this is a little bit of info that i copied and pasted out of a PM i sent DJ. it should help out in this thread as well (DJ is going to get it added into the US Lancer Tension Spec thread to hopefully keep some guys from doing something to crack the generator housing). this is straight from the shop manual and is to be used as a back-up to RRM directions incase they were unclear in any way (who am i kidding their directions are amazing)
here is the info people will need for installing the RRM or RIPP crankshaft pulleys (i'm not so sure if the belt tension remains the same on an underdrive pulley but hypothetically this is OEM recommendation)
Belt Tensions (check with tension guage)
Alternator belt: When Checked - 88-132 lbs
During Adjustment - 99-121 lbs
During Replacement - 143-187 lbs
Drive Belt: When Checked - 88-132 lbs
Pivot Bolt (alternator): 33+/-7 ft lbs
Generator Tension bolt: 17+/-1 ft lb
Tension Jam-Bolt: 17+/-1 ft lb
i hope that this will help some of you out in the future and/or anyone having trouble with belts after the install.
Old Dec 22, 2005 | 05:41 PM
  #203
ROCK's Avatar
Thanks for contributing to the community!
ROAD/RACE
Old Dec 22, 2005 | 06:56 PM
  #204
you're welcome. that's my job.
Old Dec 22, 2005 | 08:04 PM
  #205
Z_Lancer_Man's Avatar
Well, otter and I finally got the pulley in I went out and bought a 25" breaker bar and some impact sockets. I hit the nut with my 240 ft-lb. impact wrench for a couple of minutes, otter (Rob) sprayed some penetration oil on it and we each had turn on the nut with the breaker bar. I went first and loosened it up for otter who broke it loose Putting the car in 5th gear and standing on the break kept the crank from moving and we also had to jack up the whole right side of the car a good 10-12 inches to have enough room for the bar but it worked
Holy crap that stock pulley is heavy! Here is my quick review of how the car feels now....
Great! You can feel the increase in low end power, something I've deperately needed since my exhaust was put in. Car revs up faster and is overall more fun to drive. A++ to RRM for making a great product. Now about the install instructions.....
RRM neglected to mention a bolt that needed to be loosened for removing of the power steering belt. I even called RRM this afternoon to make sure that their instructions were right and that only 1 bolt needed to be loosened and the guy that answered the phone told me, incorrectly, that it was just the one 14mm bolt facing the front of the car.
Well, neither otter or I agreed that that was the only bolt. There was way too much resistance in it for supposed loosening of the belt. Turns out we were right.
You need to first loosen the center 14mm bolt located in the dead center of the power steering belt tensioner pulley, the smaller pulley under the power steering pulley (the idle pulley). You just need to crack it loose, not remove it. After that, then you can loosen the 14mm bolt under the power steering pulley which faces the front of the car.
I'm not sure how or why RRM failed to add this bolt in the instructions, but now you all know and they can add it.
Overall, I love the pulley and again RRM has created a great product
Old Dec 22, 2005 | 09:17 PM
  #206
4g94T's Avatar
and for auto guys?
Old Dec 22, 2005 | 10:48 PM
  #207
I was thinking about that same thing...... not sure what the auto's have to do. I guess you'd have to get a freaking powerful (600 ft-lb) air impact wrench.
Old Dec 23, 2005 | 06:37 AM
  #208
Originally Posted by azhunballa
and for auto guys?
That'd be "put it in park (P) & hold the brake" .
Old Dec 23, 2005 | 08:28 AM
  #209
Oh yeah.....duh
Old Dec 23, 2005 | 08:48 AM
  #210
only had to loosen one bolt on mine Vasily snapped the head off of his though. just curious, can you post a picture for me? i only have one bolt on there to loosen. could be a finite difference between the 02's and 03's shop manual only shows one as well. please look into that. pictures, pictures, pictures. it would be useful information for those who haven't done the install yet!
