What is This?!
Old Feb 21, 2006 | 12:56 PM
  #76
ambystom01's Avatar
A tune up is basically have the oil changed, spark plugs changed, and have a mechanic look over the engine and suspension to make sure its alright. No air, isn't a big deal, but the idling is kinda bad.
Old Feb 21, 2006 | 09:50 PM
  #77
CityKnight's Avatar
Originally Posted by shannoncorp
by the way what is a "tune up"?
Oh hell no... Please tell me she DID NOT just ask that!
Im sorry... I'll shut up now.
Old Feb 22, 2006 | 04:38 AM
  #78
Kid Lancer 7's Avatar
thanks
not every girl would know exactly what a tune up consists of. damm there are some guys that dont know.. so it wasnt exactly comedy central
Old Feb 22, 2006 | 09:08 AM
  #79
BudweiserJason8's Avatar
Your car is actually a very nice one. All it needs is some care. I dont recommend you take it to any shops to have repaired... Try to make some friends who know a little about cars and can help you fix it yourself. If you take it to a shop they will definitely rip you off, especially since you asked what a tune up was. I dont know if resetting the ECU will do anything but have you tried that for the idle problem? As far as the PO421 and PO135 codes go those are probably issues with the headers and exhaust which can be fixed.
  #80
shannoncorp's Avatar
thanks for telling me what a tune up is and not for making too much fun of me, and for all of the usfull information you guys gave me, you guys are really helpfull, I would be lost if it wasnt for these forums and paying some mechnic big $$$
Question someone at school told me that if my car runs lean that one of my pistols or something like that will explode or something like that is this true? and is it just me or that search thing doesnt work anymore?
Old Feb 22, 2006 | 09:52 AM
  #81
ambystom01's Avatar
The piston won't explode, it'll melt. My car ran lean after I incorrectly installed an intake manifold (must have had a leak) and I ended up replacing a sensor, all the spark plugs, 4 valves, all the pistons and piston rings, and had to have my block bored. Basically, on the stock motor lean is very very bad.
Old Feb 22, 2006 | 10:04 AM
  #82
guess I will stop driving the car till that cel elminator comes in
Old Feb 22, 2006 | 10:09 AM
  #83
ambystom01's Avatar
You shouldn't be running lean with the mods you have.
Old Feb 22, 2006 | 10:14 AM
  #84
but, for the check engine light .. it says
PO421 Warm Up Catalyst
PO171 System Too Lean (Bank 1)
PO135 O2 Sensor Heater Malcunction
does PO171 mean Im running lean or something else then?
man that sucks that ECU messed up your car like that because of a little leak..
Old Feb 22, 2006 | 10:26 AM
  #85
ambystom01's Avatar
I think the PO171 code means you're running lean in cylinder 1, but I'm not too sure whats causing it. The header definitely isn't causing it, since thats on the other side of the engine, it might be the chip or piggyback that doing that.
Old Feb 22, 2006 | 10:29 AM
  #86
TogueMonster's Avatar
I have no clue whats goin on in there, but it looks like its missing a 4G63 or two.
Old Feb 22, 2006 | 10:32 AM
  #87
ambystom01's Avatar
Its missing an evo engine and thats causing it to run lean? Never heard of that before.
Old Feb 22, 2006 | 10:46 AM
  #88
Originally Posted by Johns Slow ES
i know the p0421 is the code that the header will throw cause u eleminated the 1st cat
rrm sells a quick fix for that.
the other code esp. the o2 heater malfunction may just be the the first sensor going bad that would also give the lean code if the o2 is not getting a good reading
but as for the piggy (first congrads its like a $400 mod) it sounds like its working fine so leave it alone for now.
I remember John Slow ES saying this. did some research on the web there are some cases which match up to what he said.. not sure will find out when I get the CEl elminator.. and maybe a new O2 sensor
Old Feb 22, 2006 | 03:10 PM
  #89
WADADLIG_OZ's Avatar
The P0171 code is a bad O2 sensor code according to what I was told and what I have researched here on Evom. The auto parts store told me the same thing.
There isn't much info about it in Lancer forums but if you search the Evo forum you pull up all kinds of codes.
WADAD
Old Feb 22, 2006 | 04:13 PM
  #90
rcefstsfecr's Avatar
Never Buy A Car From Ebay!!
I've bought two cars on ebay for my parents so I don't agree with you on that at all.
