What is This?!
Old Mar 6, 2006 | 05:48 PM
  #106
iyi0521's Avatar
The chirping noise is from the Piggyback. The Version 1 piggy runs off of pressure from the FPR ( Fuel Pressure Regulator ) and it will make strange whistling and chirping noises at idle and under acceleration. Youll get used to it. I miss it when i drive the NSX.
Old Mar 6, 2006 | 08:45 PM
  #107
Alchemist's Avatar
That box is indeed the Manifold Differential Pressure Sensor. Don't buy a cheap *** eBay strut brace because the brace will rub on the sensor and break it off. They're not cheap to replace (unless you have about a half dozen of them laying around from various manifold projects )
Old Mar 7, 2006 | 05:47 PM
  #108
shannoncorp's Avatar
ah , I see thanks for all of the information guys, will let you guys know when he does the pressure test and installs the CEL for me
Old Mar 17, 2006 | 05:35 PM
  #109
ah , I see thanks for all of the information guys, will let you guys know when he does the pressure test and installs the CEL for me, update the cel and strut bar are finally comming in this wednesday , but unfortuanltay a new problem accured it dies on idels now
Old Mar 18, 2006 | 11:26 AM
  #110
eehjay's Avatar
It dies EVERY time it idles? Wow, that's bad. Sorry to hear that.
Old Mar 18, 2006 | 11:31 AM
  #111
sometimes it does but not everytime
Old Mar 18, 2006 | 12:40 PM
  #112
TEJ's Avatar
TEJ
Do you still have the piggyback installed? because if you do it is most likely causing it and you need to raise the idle. It has caused my car to die twice when my idle was lower, I was at a light and the rpms dipped low enough to cause the car to shut off. Hasn't happened again since I raised the idle.
Old Mar 24, 2006 | 10:11 AM
  #113
Update: Just recived my CEL Elimantor and Strut Bar Today, had them installed boom... IDLE PROBLEM GONE, Lean Problem GONE, Precat Problem GONE..
Only one problem remains.. PO135 O2 Sensor Heater Malcunction
does this mean that I have to buy a new 02 Sensor and then the car is like new .. but with out the aircondiction?
Thanks for everyone that helped me
Old Mar 24, 2006 | 11:02 AM
  #114
Green_Bandit's Avatar
^^^Is that the recall that was last put out?
Old Sep 27, 2009 | 04:29 AM
  #115
jester81783's Avatar
sgt petty, why do you keep posting in threads that have been dead for years?
R1ckyB0bbyyy
26
Sep 19, 2008 08:00 AM
tiffany&coNY
17
Jun 6, 2007 10:37 AM
dewood*
Apr 28, 2007 03:02 AM
evodave
For Sale - Cars For Sale
15
Oct 12, 2006 08:50 AM
