tranny and power steering fluids
Old Aug 2, 2006 | 05:40 PM
sadude's Avatar
That's a bunch of bull for us Auto guys...how expensive is the auto fluid?
Old Aug 3, 2006 | 10:35 PM
Supa_Kimchee's Avatar
i'm curious as well... how much???
Old Aug 4, 2006 | 07:07 AM
Wallesasuaz's Avatar
As for the fluid for power-steering, it ran me about 2-3 dollars a bottle. All dealers are different, but it should not be no more than 5.
As for Tranny Fluid, I'm not sure...
Old Aug 4, 2006 | 05:05 PM
Synthrocker's Avatar
Clear Power steering fluid is compatible with either ATF or "Power Steering Fluid"(clear) PS Pumps.
Meaning, you can put the clear stuff into a ATF PS system, but you cant put ATF into the clear fluid PS system- Youll more then likly ruin seals. But I'd try to keep it all one fluid anyhow.
Anyone know what the gear oil cost per quart from the dealer for us manual guys =P? My 99 VW was 45.99 a ****ing quart for gear oil, ****in bent me over. Good thing I do all my labor =O
Old Aug 4, 2006 | 05:23 PM
lancerman360's Avatar
Putting clear fluid will ruin your pump and rack. Trust me I know. I just had all that **** replaced cause the guy I bought my car from put in the wrong fluid. Costs you up the ***!!!
Old Aug 4, 2006 | 07:43 PM
My garage only stocks clear fluid, not a bad pump or rack has come back yet been working there for 2 years
Edit: Maybe he dident relize and put brake fluid in- or something. That **** will swell up and ruin seals, vice versa you put Power Steering fluid in the Master Brake Cylinder, I just worked on a car that the lady had brought her car to a Speedy for an oil change and they put PS fluid in her MAster Cylinder, Swelled the seal on the cap and lines it was leaking like a siv, needed a new cylinder, probley gotta put all new calipers on it tommorow.
Like I said we only stock clear fluid, it works with both, BUT when we do flushes if it calls for ATF, we do ATF(for the fact the the flush kits come with conditioners for the seals, and ones made to work with ATF, the other with PS fluid)
fujirio
Outlander Sport
Dec 26, 2016 10:31 PM
bluebanana23
15
Jan 5, 2016 12:27 PM
theblue
11
Dec 27, 2011 10:27 PM
mauisurf2003
Lancer Engine Tech
Jan 4, 2008 03:11 PM
memo3
Apr 18, 2004 06:03 PM
