Lancer oz
Old Nov 21, 2006 | 09:42 AM
Lancer4Life's Avatar
Hey SilvOzRallEdit, nice ride! Just wondering where you got the OZ Rally Racing sticker in the back window... Thanks :-)
Old Nov 21, 2006 | 11:01 AM
HobieKopek's Avatar
Widebands, or and O2 sensors for that matter, don't really have software. They just have voltage outputs. 0-1v is the realm of narrowband signals, widebands are 0-5v. I don't know if Zeitronix have just a 5v or a 1v and a 5v. Either way, they don't require software installs because the ECU won't understand the 5v signal. The 1v output on narrowbands is basically there to simulate the actual 5v redout into a voltage range that the ECU can understand. If you were to tap the 5v to the ECU it would constantly run pig rich.
Old Nov 21, 2006 | 03:35 PM
Zeitronix's Avatar
Wouldn't be nice if someone made a wideband controller, which instead of only reading AFR and having 1V or 5V output actually reads important engine parameters such as AFR, RPM, TPS, Boost, Vacuum, EGT and 0-5V sensors? Wouldn't be just wonderful if such a device come with logging software for your PC laptop or a Palm Pilot, matching accurate plug in sensors, a warning box which sounds an alarm before you are going to blow up your engine. Wouldn't that be nice.....
Zeitronix Eng.
Old Nov 21, 2006 | 06:01 PM
SilvOzRallEdit's Avatar
Just go to a custom shop that does tinting and other vhehicle mods and they will take a picture of your badge you want and they will blow it up to the size specified.. i lke the graphic too the artist did perfectly
dadsgts
Lancer Engine Management / Tuning Forums
Jul 7, 2013 09:54 PM
Hcaruso4
12
Sep 23, 2008 11:29 AM
neusch11
17
May 20, 2006 08:40 AM
ptb03OZ
Lancer Aftermarket Forced Induction Tech
Jul 24, 2005 05:38 PM
Sir Lancelot
Lancer Engine Tech
54
Mar 20, 2005 11:31 PM
