View Poll Results: What should be made after the damper?
Downpipe
10
19.23%
Rear Disc Brake Conversion
21
40.38%
Projectors
21
40.38%
Voters: 52. You may not vote on this poll
New Products for the Lancer!!!
Old Dec 23, 2006 | 09:02 AM
  #211
mitsulancer2.0's Avatar
I would like to see a 2,1/4" downpipe. My header, cat, and exhaust are all 2,1/4"
Old Dec 23, 2006 | 09:06 AM
  #212
02OZR's Avatar
Whats the latest news on the engine damper??
Old Jan 2, 2007 | 03:29 PM
  #213
02OZR's Avatar
bump???
Old Jan 2, 2007 | 07:49 PM
  #214
iyi0521's Avatar
Yes i is very interested.
Old Jan 2, 2007 | 08:44 PM
  #215
Z_Lancer_Man's Avatar
Also looking for an update on the engine damper
Old Jan 2, 2007 | 08:51 PM
  #216
lancerman360's Avatar
yeah what happened with the damper?
Old Jan 3, 2007 | 12:05 AM
  #217
Iamkar33m's Avatar
In all honesty, I think stiff motor mounts work much better than an engine damper. Think about it... motor mounts are spot center with the engine and stop movement in almost all directions. A dampener grabs the engine by it's outer extremety and allows the other side to just hang loose. Does that make sense?
EDIT: I actually looked into it and found that the Evo's high quality (Ingalls brand) engine torque damper is $165 whereas RRM's urethane filled motor mounts are $150.
Old Jan 3, 2007 | 07:51 AM
  #218
Thanks for the info, but we're not debating here whether or not we should use/have an engine damper. We already want one - we just want to know the status of the part.
However, if you'd like, you can always start a thread on the pros/cons of stiffer engine mounts vs. an engine damper. That could make for an interesting debate.
Old Jan 3, 2007 | 09:35 AM
  #219
crypto's Avatar
Former Vendor
its a lot easier to put on an engine damper than to fill the rear mount. i have done the front which wasn't hard, and im putting an NSC damper on also instead of filling the rear mount. it should work just as well.
Old Jan 5, 2007 | 09:03 AM
  #220
turboslik's Avatar
evo 8/9 body kit replicas for the 02-03 oz lancer.
Old Jan 6, 2007 | 08:53 PM
  #221
smalltown's Avatar
I'd like to see some rear disc drakes, and I'd like to see them done and not cost over $550 or so.
Old Jan 6, 2007 | 09:14 PM
  #222
drucea's Avatar
We don't need rear brakes. They don't work right when used on a car designed for rear drums. They would lock up if you jammed on the brakes. engine damper is a good start.
Old Jan 7, 2007 | 03:20 AM
  #223
GuamLancer's Avatar
Ok, I just got done reading ALL 15 PAGES of this thing and I'm suprised noone has mentioned it- how about a steering wheel hub that is actually made for the Lancer? I want a nice steering wheel, but have no way of mounting it!!
So far, only this "Splash" hub from more-japan.com seems to fit, according to the threads I've read. But it is for an Evo and all threads on this forum say ours is a little different from the Evo. So I'm guessing it probably won't work...
So how 'bout it? a metal bracket for the steering wheel shouldn't be too hard, I hope
Old Jan 7, 2007 | 11:32 AM
  #224
ambystom01's Avatar
Ours is not different from the evo, hence why we can use their steering wheel. I have no idea what threads you're looking at but they're wrong.
Old Jan 7, 2007 | 06:13 PM
  #225
GuamLancer's Avatar
Well, from the threads I read and those I've talked with, its different. If you buy an Evo Hub adaptor it won't fit.
If I'm wrong on this, please enlighten me, someone. I have a MOMO steering wheel ready to go, but waiting on a hub adaptor.
If it in fact does NOT fit, then maybe this guy can do it for us.
