Did some searching and I can't come up with a straight answer
Old Jun 17, 2008 | 10:24 AM
Green_Bandit's Avatar
Exclamation Did some searching and I can't come up with a straight answer
Simple and to the point...
Got a used RRM turbo kit that sems to have been non IC then converted to IC
My question is
Do I need a piggy to be running intercooled?
I've been reading that 04+ have a 5th injector set up with no piggy some with both
02-03's with no piggy some with, one with piggy and injector
I was under the impression that you didn't need a piggy unless you were going stage 2 and with that you would need larger injectors on top of that.
Time is ticking for me and and help would be appreciated.
(I would call RRM but I'm on the east coast and they are closed now)
Thanks!
Old Jun 17, 2008 | 10:27 AM
lancer2show's Avatar
their open. they open at 10am pacific standard time.
Old Jun 17, 2008 | 11:20 AM
ambystom01's Avatar
There are basically two kits, the 02-03 T-28 kit and the 04-06 16G kit. The 02-03 kit used to not use a piggy but it was changed to use the RRM piggyback for better power and reliability (since you can actually tune the car). It uses a return fuel system and an FMU to address the fuel issues. The 04-06 system uses a 5th injector since the engine has a returnless fuel system. This is controlled with a piggyback.
Old Jun 17, 2008 | 10:14 PM
Ahh thanks! I couldnt quite pin it down. I seen so many different set ups and got confused. But I got it squared away now.
05lanceralliart
Apr 3, 2009 12:49 PM
OZking425
Lancer Engine Management / Tuning Forums
Oct 31, 2008 06:58 PM
crypto
Lancer Engine Tech
May 8, 2007 02:55 AM
ptb03OZ
Lancer Aftermarket Forced Induction Tech
Jul 24, 2005 05:38 PM
reTro
Oct 13, 2004 08:59 AM
