Help! Stalling!
Old Mar 15, 2004 | 07:01 PM
azyan's Avatar
dude man take it off and send it back to them n get a refund. its not worth it if you are going through all this trouble.
Old Mar 15, 2004 | 08:26 PM
pumpdog720's Avatar
Well my first problem RRM said is to check my connections are good and to solder them. So I am going to do that, should fix the stall on startup.
And after running my car a bit with the A/C on I got some idle up and down, but now it seems to have calmed down and is running ok.
That's the problem with new products for ECU's and stuff. They might not be exact perfect untill all probelms are found out.
Maybe RRM should include in the instructions to run your car a bit with the A/C on while doing your first drive with it.
I don't want to take it back because my car is a lot faster. So with the A/C running that probelm is hopefully gone now, and I just gotta solder the wires and hopefully that problem is fixed and it would be all good. So I think it is worth the money, but you also need to be able to put some time into working with your car when you have mods and the problem is I don't always have time to troubleshoot my car. That's why I just want everything to just work for me and that's why I complain, but it will all be good sooner or later.
No bad words about RRM, they still make the best products available, and they have been helping me with suggestions through this.
mnewdigate
Lancer Troubleshooting
10
Apr 24, 2016 11:25 AM
livelyjay
Nov 11, 2013 03:58 PM
SilverLanEvo
Jul 5, 2011 10:52 AM
asahlot
10
Aug 20, 2010 06:20 PM
hotredevo
Jul 29, 2010 06:54 AM
