tein coilovers? TALK HERE
Originally Posted by Pick_a_Fro
ROCK or you other knowledgeable members on here prolly would know the answer to this question. Do TEIN BASIC Coilovers on the Ralliart fit on the 02-03 regular Lancers? A vendor says it does and he's selling a set for a super kick *** deal and I can't pass on it. So I need to know super ASAP! I'm asking cuz on prostreetonline.com, they got two seperate product numbers for them.
Originally Posted by Handmemyarms
well, i got one more question and then i think ill call it quits on this thread, any hieght recomendations?
actually thinking about it... i have 40 in the front and 35 in the rear... and the gap seems to be about even between the front and rear. When i get it corner balanced sometime this spring/summer ill post up how much thread it is on each corenr... should allow people to be pretty close to balanced +/- a few lbs for driver weight
around 3-400 plus an alignment after that. Seems to be about the running rate around here. And you have to be there the entire time unless they have a staffer whose weight is close to yours.
it goes like this... weigh the car... lower a side... weigh the car raise a different side... weigh the car opps raised it too much lower it down a lil... but having it tuned would be beneficial if you race the car. If not, just get an alignment and be done with it.
god !@#$%^&*(ing damn it, now super$#!+bacs wont install anything unless you buy it from them, what a bunch of crap, i shoulda just stuck with road race for the instal from the start, now im just pissed at myself
Originally Posted by GreenPsycho
maybe i missed something, but why can't you install them yourself?
good luck with it man, i'm sure it'll be worth it in the end
because when it comes to something as major as this, the last thing i wanna do is screw it up, id rather have people with expierience and who have done it before do it, i think its worth the cash
Just do it yourself. It's very easy. But get someone to help. Four hands work better than two.
EDIT - what's to screw up? Pop them in, tighten all the bolts, and set the height/dampening as needed. Unless you leave a bolt off, you're fine.
