Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Power Steering
Old May 5, 2006 | 03:17 PM
  #31
lancerman360's Avatar
Yall are probably right. Just make sure its not normal old p/s fluid
Old Jun 14, 2006 | 03:20 PM
  #32
problem solved. Got a new rack and pump put in. Now the darn steering sensor is going out. At least I can drive my car now!
Old Dec 17, 2006 | 10:31 AM
  #33
jchangsta2six's Avatar
sorry to bring back a dead thread .. but i have read many of these power steering fluid threads .. and i want a cut and dry answer. what have people used besides Diamond SPII that has worked? if worst comes to worst i will be just getting redline ... by the way, i am just refilling it cause its low, is it bad to mix?
edit: i found this site .. it saids that castrol ps will work for mits. brands ... any input?
Old Oct 26, 2008 | 07:17 PM
  #34
robere123's Avatar
Have a 2004 Lancer OZ . . . Can I use ATF Fluid for Power Steering Fluid?
thx
RR
Old Oct 27, 2008 | 07:22 AM
  #35
lancer2show's Avatar
thx
RR
if the tranny fluid is made for transmission than only use it for the transmission. i mean i wouldnt even use regular oil for my transmission. besides atf cost more than power steering flud anyway.
Old Oct 28, 2008 | 06:34 PM
  #36
robere123's Avatar
So . . . I went to the local autoparts store and picked up a bottle of
http://www.bardahl.com/mods/gallery/...&box=&shownew=
It's synthetic, so it should be robust . . . So far so good . . . I'll keep you updated if I encounter any problems . .
I in no way endorse this product, its just the only fluid I can find.
The coulor is clear (with a slight yellow tinge) . . . Doesn't match the OEM red type fluid, but I've flushed in 2 bottles of Bardahl. Basically drained the resevoir, and refilled with a bottle of Bardahl, started the car to mix in the fluid . . . I did this twice
Old Oct 28, 2008 | 07:25 PM
  #37
evoguy69's Avatar
power steering
Originally Posted by lancerman360
Ok I just installed the new pump and the squealing noise comming from the drivers side enging compartment is still there. I found that its the pressure hose has a small leak and thats where the noise is comming from (see pic). I will call the mitsu. dealer tomorrow to see if they can look at the hose and find out what the problem is. Oh yeah my old power steering fluid was almost black compared to the new clear fluid, there is something bad wrong. my car has been wrecked in the front passenger side.
i have a good line for sale.i just replaced my rack 34k miles on the car. the rak i bought came with high press line so i just reused the one that was on car. make me a offer. thanks,keith 704 789 3367
Old Jan 16, 2009 | 11:12 AM
  #38
robere123's Avatar
So far so good with the bardahl power steering fluid.
Skyline Fever
13
Jun 11, 2012 07:35 AM
Houstonsc300
Mar 21, 2011 07:01 PM
Carrier
Lancer Troubleshooting
18
Aug 8, 2007 01:56 PM
JT-KGY
Nov 23, 2003 09:24 PM
CombatCQB
Oct 28, 2003 05:17 PM
