Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
My highbeam doesn't work!
Old Mar 20, 2006 | 08:33 AM
initialDRacer's Avatar
Hi,
Does anyone know why my highbeam doesn't light up? I pullback on the knob and no light comes on. My lowbeam works fine. What's weird was that when I put the knob on the middle position and pullback on the knob, the lowbeam lights up. Any help would be nice...
Old Mar 20, 2006 | 09:13 AM
Danno's Avatar
Change your light bulbs with new ones.
FYI your car uses 9007 bulbs.
Old Mar 20, 2006 | 10:12 AM
Walkingchaos's Avatar
check your fuses as well, if its both bulbs odds are its either a fuse or the switch actually in the steering column is shot.
Old Mar 20, 2006 | 10:18 AM
Sonantoni's Avatar
bulbs
Remember our bulbs have 2 filaments, one is on with reg. beam, both turn on when you turn on high beam. tend to burn out quicker when you use your high beam often.
plus are both not working or just driver/passenger side?
Old Mar 20, 2006 | 11:38 AM
Any recommendation on what 9007 bulbs are recommended? I bought the Silvania 9007 at autozone so I guess those are wrong bulbs?
Old Mar 20, 2006 | 05:27 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
no i use those no problem
Old Mar 21, 2006 | 05:35 AM
Hmmm, what does it a dual filament look like? Mine looks just like a normal bulb. Oh yah, where in the fusebox do you check?
Old Mar 21, 2006 | 02:09 PM
umm the lower left cubby if u pull it out i think the fuse descriptions is printed behind it.if not i'll pull up the diagram for u at work and post it. and all headlights should be dual filatment i think not sure.
Old Mar 21, 2006 | 03:24 PM
Ok, got it. Thanks!
Old Mar 24, 2006 | 12:13 PM
Welcome
Old Nov 25, 2021 | 11:40 AM
718UCJesus's Avatar
2002 Mitsubishi lancer es
I'm having the same issue I had switched to LED lights and had been working fine hi and low. Just recently my high beams will not turn on. High beam fuses checked they was fine still replaced and nothing. Guessing it's the steering column switch since there is no headlight relay fuse ugh 😩.
polish_pounder
Aug 5, 2016 02:09 PM
Jp7
Apr 21, 2008 07:54 PM
bw1
Apr 14, 2008 04:32 PM
Ahnospell44
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Sep 5, 2007 01:01 PM
NoTiGuY
12
Sep 11, 2004 12:40 AM
