Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
**How to change your oil**
Old Nov 6, 2006 | 03:25 PM
wickdaddy's Avatar
I didn't see a post up of a how-to-change-your-oil for US Lancer... so here it goes...
Here is my engine that we are changing the oil on
Here are the products that you will need: Mobil 1 Extended Performance Fully Synthetic Oil, K&N Oil filter, something to drain the oil into, a car jack and some jack stands (I like to use a ply-wood board to lay on and to keep the oil that doesn't make it into the pan from draining on my driveway).
After you put the car up on jacks, make sure to take off the oil cap to release the pressure.
This is the drain plug that is going to be removed to drain the oil
Now if you are like me, the drain plug wasn't real easy to just twist right out... I need to use a little more force
This is sometimes the only way to get a tough plug off... here is a comparison of the old plug and the new plug
Now the oil is finished draining out of your oil pan, you can unscrew the old oil filter
After taking out the drain plug and oil filter you will need to replace them with your new drain plug and K&N oil filter
Now pour your oil in the engine
Finally, put your oil cap back on, lower your car and you should be ready to roll for the next 15,000 miles!
Old Nov 9, 2006 | 10:31 AM
Blacksheepdj's Avatar
Discuss this thread here.
crypto
22
Feb 1, 2017 11:39 AM
clifhanger87
46
Oct 30, 2016 07:11 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
blaze_125
Lancer Tranny/Drivetrain Tech
29
Mar 24, 2016 10:02 PM
Mr.Evilution
Aug 5, 2006 11:54 PM
