How to install: RRM crankshaft pulley
Subscribe
Jul 16, 2007 | 03:41 PM
P.S. mods....is this sticky worthy?
Hey guys and gals, got my Al crankshaft pulley from RRM.
overall, the mod is very very easy. but me being a newb, I was very hisitent about performing this. sorry for the crap pics, I forgot my digital camera, by the time I figured that out, i had the fornt tire off already, so I used my cellphone camera.
Tools needed:
5/8 box end wrenth
22 mm head for the crankshaft bolt.
oil
jack stand
jack
impact gun ( need a force above 155 lb/ft)
or some strong arms.
a friend ( I found it to be a lot easier with a friend with ya)
screwdriver both kinds
Step 1: Take of the wheel
Step 2: With a flat head screwdriver, pry out the black clips holding the plastic guard on. This will expose the crankshaft.
Step 3: Right above the crankshaft there is a tensioner pulley, use the box 5/8 wrench and turn it clockwise, it has some spring force on it so when turned clockwise, it will loosen the pully so you take off the stock crank. unscrew using either brute strength or a impact wrench.
Step4: Swap, dab some oil on the screw and screw it back in with.
Step 4: Make sure all pullies are on correctly and are sitting in its correct seat.
( just to make sure I had everything right, I used a phillips head to take off the plastic bottle where the collent goes in to get a better look and fit my hands in there.
Step5: start upthe car make sure everything is working right.....put the skirt back on, then wheel, use a star pattern to screw on the wheel , so its even.
Step6:jack down, Rip it up.
Anyone who has this car knows how slow first gear is, my first impressions is that getting out of first gear was much quicker. I was very surprised of how easy this mod was, the only hard part was to figure out where to put the RRM decal they dropped in the box
Reply 0
Nov 3, 2007 | 04:59 PM
Do you feel any difference in hp?
Reply 0
Nov 3, 2007 | 05:44 PM
Can you notice any change ?
Reply 0
Nov 4, 2007 | 01:53 PM
Quote: Can you notice any change ?
With a standard gearbox or using the sport mode on the CVT, you'll definitely notice the difference in the low-end. Just using the CVT alone you won't notice a huge change, but the pulley will give it some pep.
Reply 0
Nov 12, 2007 | 02:42 PM
yea ...i feel top end power is fast and it increased low end o so slightly..definitly ffaster out of irst gear
nj 08 gts.......we should get a meet together..I'm from staten island
Reply 0
Nov 23, 2007 | 02:26 PM
Does the bolt holding the pulley need to be torqued down to a specific number, or do I just crank on it 'till it won't move?
Reply 0
Nov 23, 2007 | 04:22 PM
Quote: Does the bolt holding the pulley need to be torqued down to a specific number, or do I just crank on it 'till it won't move?
150 ft./lbs.
Reply 0
Dec 16, 2007 | 08:44 AM
Quick question rock, or anyone who has the pulley...
I've never heard anything about when putting the pulley back on and the belts back on to turn the tensioner clockwise. So, you turn it counterclockwise to loosen it, but you don't need to do anything when putting the belt and pulley back on right? Or do I need to turn it clockwise to put the belt back on.
Reply 0
Dec 16, 2007 | 09:55 AM
make sure to dip the screw in oil before replacing the pully. and its impossible unless you got the car in the air to use a torque wrench. So you will need a impact gun. And just torque it a good amount.
AFter you replace the pully just put the belt back on and turn the vehicle on to make sure the car is runny properly.
O and remove the neg terminal during the install so when you turn on the car give it about 15mins idle so the car can learn the new parameters.
Reply 0
Dec 16, 2007 | 10:19 AM
When you put the belt back on, you need to move the tensioner pulley the exact same way as when you took the belt off. FYI: When putting the belt back on, I found it easier to work from the top of the engine bay and slip it over the idler pulley. And like FinestSoldier said, give it a test start before you put everything back and cleanup your tools. Listen for belt squeaks and excessive engine vibrations...those are signs you messed up somewhere.
Reply 0
Dec 16, 2007 | 10:45 AM
Thanks guys, so I don't need to turn it clockwise or anything.. just move it back to where it was? (i.e. with my hand?)
Reply 0
Dec 16, 2007 | 11:05 AM
Quote: Thanks guys, so I don't need to turn it clockwise or anything.. just move it back to where it was? (i.e. with my hand?)
If you can move the tensioner pully with your hand, stop working on the car and become a professional arm wrestler.
Reply 0
Dec 16, 2007 | 11:11 AM
you need to use a tool i think its a 5/8th wrench on the tensioner pully. you turn counter clockwise and it should be very hard and the pully will move which will loose the belt, take off the belt. swap pullys, now to put the belt back on you have to once again pully counterclockwise on the tensioner and squeeze the belt back on. ITS VERY VERY VERY TIGHT. You might want a friend to help. But its possible to do on your own.
Reply 0
Dec 16, 2007 | 02:55 PM
Quote: If you can move the tensioner pully with your hand, stop working on the car and become a professional arm wrestler.
Dude, not sure if you weren't capable of reading or anything, but I was asking about after the pulley is done and putting the belt back on.. what and which way would I have to turn the tensioner or do I even have to turn it at all.
Finestsoldier, thanks for claring that up. I see how it works now. I assumed that once you turned it c-clocwise, it stayed that way and you would have to tighten it back up. Thanks for the heads up.
Reply 0
Dec 16, 2007 | 07:25 PM
here to help
Reply 0
