Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How to: Change Belts and/or Crank Pulley for 04+ ES
Old Nov 15, 2009 | 01:54 PM
joshisjamesbond's Avatar
Hey,
Didn't want to start a new thread for JUST this question.
I can't figure out why after I replaced the serpentine belt on my car that the screw that moves the pulley is a bit cocked inwards. Are the screws that hold the pulley and adjust the tightness messed up? The pulley itself appears straight and nothing seems wrong when driving/idling the car.
Old Jul 27, 2011 | 10:40 AM
Purpony's Avatar
Originally Posted by joshisjamesbond
Hey,
hey I'm going to bring this thread back from the grave as it were. I have this same question and problem with a lancer that I just bought. If anyone has any information PLEASE help me. The car makes a squealing sound when under load from the A/C being on, but otherwise when the A/C is off it will squeal when leaving a stoplight.
Old Jul 27, 2011 | 10:45 AM
lil' jeff's Avatar
you need to change the belts. while the belts are off spray carb or tb cleaner on the pulleys make sure their free of oil and everything. did that to mine and solved the problem.
Old Jul 27, 2011 | 07:03 PM
Purpony's Avatar
I have both belts and will be changing them tomorrow but have you ever heard of anyone having the cockeyed tensioner bolt problem before
Old Jul 28, 2011 | 04:28 AM
lil' jeff's Avatar
no but i believe i got that whole set up i can sell to you if you need it. i would change that,dont sound good.
Old Jul 28, 2011 | 05:35 AM
slatermvp's Avatar
I have because I have it on my car. The pulley is straight but the bolt facing the front of the car is crooked. I think it has more to do with the way it was tighten up.
Old Jul 28, 2011 | 05:55 AM
lil' jeff's Avatar
well i know that when you tighten it up and back it off a little bit ,it does have a lil wiggle room but i still wouldnt trust it.
Old Jul 28, 2011 | 09:07 AM
Purpony's Avatar
swapping belts at noon and will be trying a few different things as far as the order in which I tighten the tensioner bolt down....... although it just seems so shoddy because of the cockeyedness, makes me nervous, so liljeff I may take you up on that tensioner if the squeal wont go away with the new belts.
Old Jul 28, 2011 | 09:19 AM
lil' jeff's Avatar
just let me know. if your at the front of the car facing the engine its the same as righty tighty lefty loosy.its going to take a lil bit of turning its a long winded sucker.
Old Jul 29, 2011 | 07:07 AM
Purpony's Avatar
Yeah I will let you know whether or not I want that tensioner assembly.......
Old Jul 29, 2011 | 07:23 AM
lil' jeff's Avatar
ok ill be at the shop tomorrow and ill locate it just in case.
anthonypazsd
135
Apr 2, 2026 12:56 PM
tjwphoto
67
Apr 4, 2020 02:32 PM
clifhanger87
46
Oct 30, 2016 07:11 PM
Pal215
Oct 29, 2015 04:32 PM
Blacksheepdj
35
Jun 18, 2011 12:17 AM
