Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
Mirage / Lancer Compatibility?
Old Jun 28, 2006 | 05:19 PM
  #106
bahamut's Avatar
https://www.evolutionm.net/forums/se...archid=2754692
Search for Adam's thread.
https://www.evolutionm.net/forums/sh...hlight=adamj39
The thread in his own word.
Old Jun 28, 2006 | 05:23 PM
  #107
comatose721's Avatar
Mirage UDP Review:
https://www.evolutionm.net/forums/sh...98#post3223598
Old Jul 20, 2006 | 06:44 PM
  #108
LancerAdam's Avatar
Ok went to the dealer today and found out the Diff casing is the same for the mirage, this would indicate we could use a LSD for a mirage!
Old Jul 21, 2006 | 12:26 AM
  #109
revolt4revolver's Avatar
whats the bolt pattern on the 97-o1 mirage?
Old Jul 21, 2006 | 05:09 AM
  #110
LancerAdam's Avatar
Im not sure but the part number for the entire transmission is only one number diffrent. so we comparied the part numbers for the internals. it looks as if the gearing is slightly diffrent. yes the 97-01 mirage, i will compair the flywheel numbers tonight. if they are the same part number then yes the bolt pattern will be the same.
Old Jul 21, 2006 | 01:33 PM
  #111
Evo666's Avatar
i bet the bolt pattern is the same And yes you can use the lsd from us.
Old Jul 21, 2006 | 05:57 PM
  #112
LancerAdam's Avatar
Yes i have confimed with Mitsu. The part number for the flywheel is the same for US lancer and Mirage
Old Jul 21, 2006 | 05:58 PM
  #113
LancerAdam's Avatar
So the bolt patter will be the same too!!! Hope all this information helps
Old Jul 31, 2006 | 06:26 PM
  #114
LancerAdam's Avatar
If there are any other questions, about compadability please ask and I will cross the numbers for you, my dealer gave me the software to do it.
Old Aug 12, 2006 | 08:46 AM
  #115
bahamut's Avatar
Flywheel: G92 = G93 = G94. TODA's flywheel for the G92 MIVEC was used in an 5g turbo'ed mirage long time ago.
G92 shares the same block w/ a G93 but smaller crank + rods combo.
Old Aug 16, 2006 | 08:52 AM
  #116
my-lancer's Avatar
Hey, you guys are awesome. Thanks for all the usefull info. Def. will help with my project.
Old Aug 16, 2006 | 03:50 PM
  #117
bahamut's Avatar
I'm not sure if the latter lancer models have different flywheel. During the years of the 5g mirage, Mitsu constantly mucked around its emission. Mitsu seemed to muck all around the lancer nearly every progressing year.
Old Dec 15, 2006 | 01:43 PM
  #118
Silens's Avatar
just wanted to drop in a confirm that the Mirage flywheel does fit a lancer, i just installed a Fidanza aluminum flywheel for a 97-02 Mirage, havent had any problems with it, and was a lot less than what the lancer flywheels go for.
Old Dec 16, 2006 | 07:37 AM
  #119
my-lancer's Avatar
Thanks alot. Where did you buy it from?
nytalonTSi
Jun 11, 2011 09:29 AM
ezzey
Mar 27, 2011 09:26 AM
hcj
Lancer Tranny/Drivetrain Tech
Oct 22, 2008 04:04 PM
mirage 4g93t
Apr 22, 2008 03:56 PM
Mirage4g93
12
Aug 23, 2007 02:41 PM
