Alpine IVA-D310 bypass in a Lancer RA
Need Help!!!
I am assistaing another member on here with an install of a new Alpine IVA-D310 indash unit, now in my past experience to bypass a tv unit one would simply afix a toggle switch. The issue we have run into is this unit has 2 wires #1- an ebrake connection, #2 - foot brake connection. Now I really don't feel like running an extended wire all the way to the brake connection and splice or piggy the connection only to have Phil repeat a retarded tap and pull series of events to get the video to play. Is there any recommendations for this to bypass the safety feature esily?? I'm looking under the center consloe area so the wiring can be kept hiden and clean.
And before anyone rants, yes I am aware of the safety feature and why it is there, yes we are aware of the dangers.... but right now this is strictly for car shows or events.... so I don't need the flaming. Help is more than appreciated.
oh and yes I have googled it, nothing was specific enough for this vehicle.
i thought about that, unfortunatley 1 wire is a positive +12V and requires a pulse signal (hense the brake pedal) and the other is a (-12V) for the ebrake, i've just grounded that one, man I hate these new safety features, I mean I know why they are there, there has to be away around them, as stereo shops can bypass displays.
From the looks of the diagram in the manual, they both connect between the brake light signal and the bulbs the signal would light. Based on that, I think they're both looking for +12v, just that the e-brake must be continuous, and the foot brake should be on, then off.
If you have them laying around, try a toggle switch for the e-brake wire, and a momentary contact switch for the foot brake.
Originally Posted by owner's manual
To watch a video source, your vehicle must be parked with the ignition
key in the ACC or ON position. To do this, follow the procedure below.
1 Push the foot brake to bring your vehicle to a complete
stop at a safe location. Engage the parking brake.
2 Keep pushing the foot brake and release the parking
brake once then engage it again.
3 While the parking brake is being engaged the second
time, release the foot brake.
In the past... I've used a push button switch (like a valet switch from an alarm) to replicate the foot brake and a toggle on/off switch to replicate the e-brake.
OR
You could just buy a PAC TR-7 module and it'll do it all for you.
Hope this helps,
Nick
OR
Hope this helps,
Nick
cchan3761
42
Oct 30, 2008 08:50 PM
vetboss
13
Jan 1, 2008 11:18 AM
regione
30
Jul 24, 2004 01:58 AM
