Remote Starter
Old Jul 23, 2012 | 06:17 AM
marell31's Avatar
Remote Starter
Can someone tell me... 1. Whats Better.. Aftermarket or OEM remote starter..
2. If aftermarket... wich one works completely with the fast key and "touch to open" with no issues.. 3. Im on a budget so nothing to expensive,
Im a noob so please
P.S I Just need the remote starter... not interested in alarm...
Old Jul 23, 2012 | 09:52 AM
rzrxn's Avatar
what year is your RA?
Old Jul 23, 2012 | 05:07 PM
CrAnSwIcK's Avatar
it's at least an 09 by his avatar picture...this section is for all models and years
Old Jul 24, 2012 | 03:20 AM
marell31's Avatar
Yes is a 09...with fast key and touch to open...
Old Jul 24, 2012 | 07:56 AM
CrAnSwIcK's Avatar
we don't have those features...and a lot of the active members for the second gen lancer ralliart don't even post here...you might be better off posting your question in your engine section and get flamed for posting in the wrong section if it comes to that...lol, just think them here if they call you out good luck.
Old Oct 17, 2014 | 11:46 AM
cmb70's Avatar
OEM vs Aftermarket
From my understanding, there is not an OEM remote starter for the 09+ Ralliart and to use an aftermarket effectively, you have to hide a FOB in the car somewhere which means your car is never secure. I will check into this some more and post up what I find later.
Old Dec 22, 2014 | 11:11 AM
cmb70's Avatar
Not sure if the remote start ever happened, but check Compustar out. They do have one that will work very nicely in the Lancer RA with pass key etc. There is a bypass module that makes it so you do not have to give up a key also. I will be installing one on my car soon. I will post a how to when I get to it.
Old Jan 11, 2015 | 06:35 PM
Papa Truble's Avatar
Install
Have you had a chance to do the install; did it work out with the Key still?
Old Jan 15, 2015 | 09:33 AM
cmb70's Avatar
I did not install one on my car yet but we did some research at work. The Compustar module will allow you not to give up a key as well as Vipers. I am leaving soon on a deployment and will install a Compustar on mine when I return.
Old Jan 23, 2015 | 12:11 AM
Raikiri's Avatar
So just figured I'd chime in here since I just got my remote starter installed. It does work without having to give up a key. You just need to get a module to communicate with the CANBUS system within the car. You can either get the DBALL2 or something similar that you'll just need to get programmed to the car. I ended up buying my own system and having my friend at install mine and used the module that they use on their remote starts at the dealer. So far works just fine with no complaints.
But yeah I assume we all have the fast-key system and it works just fine with it.
Senseiz
20
Apr 12, 2017 09:04 AM
whitaker3663
Apr 8, 2016 05:24 PM
Lancer_GTS_740
Lancer Troubleshooting
Apr 26, 2011 09:22 AM
mattp_160
Jul 26, 2010 06:35 AM
Sap12687
Jan 22, 2007 09:53 PM
