My Pride, My Lancer, My Problems
Old Oct 16, 2005 | 12:57 PM
  #46
Boeturbolancer's Avatar
You'd have to rehone... new rings with proper gapping... then reinstall for it to be right. As for cost you'd have to call a shop. For me i only charge about 500 to do that.
Old Oct 16, 2005 | 05:01 PM
  #47
HobieKopek's Avatar
Originally Posted by gregivq
What are the consequences of improperly gapped piston rings???
Can I just live with it or is it fix it ASAP?
Low/lost compression, blowby, broken rings, complete engine failure....
EDIT: Eh, just saw the 1 post when I replied. Didn't realize this had been going all weekend. Boe knows what's up.
Old Oct 18, 2005 | 02:41 PM
  #48
oneEVO8two's Avatar
bumpage
Old Oct 18, 2005 | 02:42 PM
  #49
oneEVO8two's Avatar
nice ride
Old Oct 18, 2005 | 08:29 PM
  #50
N1te's Avatar
thanks man
Old Oct 19, 2005 | 10:40 AM
  #51
gregivq's Avatar
I called RossPistons today and described the noise (should have done it when I got my car back). They said the wall/piston clearance might be too big and that could cause the noise.
Consequences:
-oil consumption (could cause detonation)
-smoking
-reduction in compression
All that could happen but over some time. They told me I should not worry about it. Just let it warm up for five minutes and then make sure the motor is well tuned (timing, AF ratio) and have fun. If it will start braking there will be noticable signs. They also told me to check with the guy who worked on my motor (DAH!) if the wall clearance is around 4 or 5 if it's more/ less it's not good. I tried calling him but really I don't know what is it with my number that he doesn't want to call me???
Just like N1te I will keep playing with the motor until it will finally DIE.
Old Oct 19, 2005 | 06:50 PM
  #52
N1te's Avatar
this 4g94 shall fight to the death! ... or something like that
Old Oct 21, 2005 | 10:53 AM
  #53
gregivq's Avatar
Can I play too?
http://s24.yousendit.com/d.aspx?id=0...Y3D4FC46GAC1MN
^Just when you start the engine. Make sure to adjust the volume. It's really louder when you are inside.
http://s24.yousendit.com/d.aspx?id=2...Z0B6Y1LHRM0CND
^And the engine bay.
Old Oct 21, 2005 | 12:03 PM
  #54
N1te's Avatar
thanks greg
Old Oct 21, 2005 | 12:16 PM
  #55
gregivq's Avatar
No problem. That's my turbo diesel. It only sounds like that because I use 93 octane instead of diesel fuel. j/k noobs
Old Oct 21, 2005 | 01:11 PM
  #56
have either of you guys had a chance to compression check your engines?
Not that i'm trying to worry you at all... just want to know your results.
If you haven't and can please do so and let me know what your readings were.
Thanks,
Boe
Old Oct 21, 2005 | 01:39 PM
  #57
gregivq's Avatar
I will do it during this weekend.
Old Oct 21, 2005 | 03:40 PM
  #58
sweet...
Old Oct 21, 2005 | 04:06 PM
  #59
ambystom01's Avatar
On monday (hopefully) I can see if mine does that as well.
Old Oct 26, 2005 | 09:22 PM
  #60
N1te's Avatar
amby what's the deal? and how do you adjust the clearance space for the valves/pistons? Boe? Hobie? Alchy?
