4g63 Swap Thread(Mad_Canabice)
Old Apr 25, 2009 | 04:39 PM
  #151
MaD_CaNaBiCe's Avatar
yeah the evo brembos are going in....not sure about the rear yet though since i need this car running sooner than i thought i may not find the time to fabricate the outlander rear backing plate or ralliart ones depends which one i use.Anyways got tho dash out today and started to take out the wire harness but decide not to until the evo harnesses get here so i can do a comparison of both got my fingures crossed that it will all be plug and play since i'll be having the dash and engine harnesses except i am expecti9ng the evo harness to have a few more wires fot the abs and all that stuff.... can't find my cable for my camera to upload any pics
Old Apr 26, 2009 | 12:15 AM
  #152
fearthisrc's Avatar
Hey i'm doing a different swap, but wanted to give you a tip on the harness. I just pulled mine out of my car, and it is a 2 piece harness. The engine harness is completely seperate from the interior harness. Because i took the every wire in the engine bay out plus the computer and could still hook up the battery and listen to music and all the lights work. The only acc. attached i believe are the wipers or wiper spray, one or the other. So if you are afraid about that i would say go ahead. But just letting you know if you didn't already.
Drive safe!
Old Apr 26, 2009 | 06:17 AM
  #153
Drive safe!
Thanks for the info but I already knew it was a 2 piece harness since i've taken the one oup of my engine bay the only wires that are still in there are the fuse box which runs through the driverside fender to the interior fuse box and harness but what I am wondering is the if the Evo harness has the same setup or if it is a very similar setup can you confirm this? thanks!!
Old Apr 26, 2009 | 06:20 AM
  #154
turbotime's Avatar
I have a evo harness and just pulled the engine out of my car and started prepping for the rwd. I haven't touched the wiring yet but I can take a look this week for you can let you know.
Plan is to run evo fuse box and accessory wires to run the hid headlights...I'm hoping it plugs into the lancer interior harness.
Old Apr 26, 2009 | 06:28 AM
  #155
well i got my fingers crossed also because the dash harness seperates when it runs to the back i'm guessing that connector is for the tailights and everything else behind there.
Old Apr 26, 2009 | 10:04 AM
  #156
Still kinda puzzeld about where the line for the cluch runs through and how the line and the clucth pedel mounts so just wondering if i have this labeled right.Here is a chassis for a RHD Evo 7 and my chassis for comparison
Evo 7 chassis
Old Apr 27, 2009 | 05:04 AM
  #157
shawnevo8's Avatar
take that black peice off of the firewall you'll see it, and yes that was the line.
Old Apr 27, 2009 | 09:04 AM
  #158
ok well that ios why i am puzzeld i took it off since it is going to be next to the brake booster and the unstmped part of the firewall is ahped different oh well i'll figure everything out when the parts get here
Old Apr 27, 2009 | 12:54 PM
  #159
shawnevo8's Avatar
why didn't you go with a tilton pedal assembly? you could leave abs off, plus it comes with an adjustable bias built in. google them, it's what i would do.
Old Apr 28, 2009 | 04:25 PM
  #160
ok well i got the dash out and decided to snap a few pics.here is what it looks like can anyone copy this pic and label where the clutch pedel mounts and where the hole for the clutch line run through.
pic from engine bay
pic from under dash
Old Apr 29, 2009 | 05:39 AM
  #161
shawnevo8's Avatar
directly to the right of the brake booster where that stud is, you'll have to look at the clutch master cylinder, and the pedal assembly. then just cut and bolt
Old May 2, 2009 | 09:57 AM
  #162
Chameleonzero's Avatar
You got a lot of work to do but if you can do it you will be the first i've ever seen do this...Look forward to the end
Old May 2, 2009 | 10:08 AM
  #163
lookslikeanevo's Avatar
^ummmm...no....do better research...there is a guy with SCLC, that basically just needs a tune
Old May 2, 2009 | 04:28 PM
  #164
Juan Martinez's Avatar
Ok, here are those pics I was going to help you with.
The first 4 are of my 5 speed OZ rally, the last 3 are of the Auto ES. You shouldn't have to change the resevior on the brake booster. It has a bung on the side that you just tap into and run a hose from it to the clutch cylinder.
Old May 2, 2009 | 10:40 PM
  #165
Update got my parts today and started to bolt everything in
fender had to be remaoved to take out the dash harness
after taking about and hour and finally getting the dash harness removed I started to fabricate the clutch pedel and clutch pump
never really came out the way I planned but atleast everything falls inline I will be having my welder come by and reinforce this area o the firewall when i and weling the bracket for the right engine mount that our lancer don't have
Here is what finnished pedel set looks like (bye bye automatic)
Here is the evo engine harness and the booster pump for the brembos
Only thig that has me puzzeled at this point is the 4 brake line that our lancer have whilst the evo brake booster has only 2 I will have to do some research on this.
Tommorrow I am going to start putting in the dash harness and hopefully hook up the battery to see what works lol
