Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Motor mount is on (front at least)
Old Aug 29, 2006 | 09:57 AM
ambystom01's Avatar
I don't even see how you would do it without removing the crossmember. I searched on here and found nothing, if you want to make a how-to thread, be my guest, I'm sure it would be very much appreciated.
Old Aug 29, 2006 | 10:16 AM
Grey_Fox's Avatar
https://www.evolutionm.net/features/...rrmcorner/14/2
FROM the RRM Corner Article
This will tell you how to remove the Front Motor mount w/o removing the member.
Old Aug 29, 2006 | 10:31 AM
airlinevomitbag's Avatar
Dude I put a picture up in a thread recently that I think you started of how to postion the tools and manipulate them to make it work.
Old Aug 29, 2006 | 10:37 AM
ambystom01's Avatar
The problem with the RRM article is that it doesn't show or say anything on how to get the two problem bolts off. The pics in the thread I started were helpful for getting the middle bolt off, but the two holding it to the cross member were damn near impossible, especially the rear most one. I ended up using a wrench for that and going a quarter of a turn at a time. Dropping the crossmember is by far the easiest method, and I can't see any reason not to do it.
Old Aug 29, 2006 | 10:56 AM
Just to make sure I'm not crazy I went out to the garage and cracked both of those bolts loose with a 14mm 3/8" drive craftsman socket, about a 6" extension and a chinese 3/8" rubber grip handled socket wrench.
Old Aug 29, 2006 | 11:01 AM
ambystom01's Avatar
I tried various length sockets, different angles, all that and I couldn't get em. Maybe my socket bits are too thick or something but that rear one just wasn't happening using sockets, the bits wouldn't fit through the hole between the mount and the engine.
Old Aug 29, 2006 | 11:19 AM
Kurt's Avatar
Here is my problem with the rear mount. I got all four bolts that hold it down out. I even got the bolt that runs through the motor mount removed. That is where I can't figure it out. Also, I can't seem to get the four bolts back in.
Old Aug 29, 2006 | 11:25 AM
Put those 4 bolts in before you put the center one in. You can jack the motor around to get the center one lined up later.
Old Sep 5, 2006 | 10:55 AM
Kurt's Avatar
I took it to my mechanic. I am happy with the having both mounts done.
Old Sep 8, 2006 | 10:43 AM
Blacksheepdj's Avatar
Does your whole car shake with the A/C on high now? Or was that just mine?
Old Sep 8, 2006 | 11:20 AM
Kurt's Avatar
It shakes once in a while, but that is because of the low idle. Once I get the reflash, I will have the idle adjusted and get rid of any shaking.
Old Sep 8, 2006 | 11:42 AM
You will have to get it to idle around 850 or higher for it to be smooth. I like the shimmy in mine.
Old Sep 8, 2006 | 05:56 PM
03RallyLancer's Avatar
mine doesnt... but i also got the deyeme flex set
Old Sep 9, 2006 | 07:02 AM
Always scared the hell out of my passengers. "Is it going to fall apart?"
Old Sep 10, 2006 | 09:25 AM
N1te's Avatar
I'll be doing this during the week.
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
54
Mar 13, 2017 01:27 AM
EGbeater
Jan 16, 2016 04:14 PM
blk-majik
Jul 20, 2015 08:18 AM
luckybull
Sep 19, 2013 12:19 PM
airlinevomitbag
Lancer Engine Tech
10
May 4, 2003 10:41 PM
