Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
MT Vs. CVT
Old Mar 23, 2008 | 01:33 PM
  #181
RC2099's Avatar
Its all ground level driving (<= no interstate) and there are only a few places in Las Vegas (city limits) that are over that. It does really help. There are a lot of things you can do to get better gas milage.
First step is an amputation. Got to cut off the lead foot.
Scott
Old Mar 23, 2008 | 02:06 PM
  #182
MasterAK's Avatar
^^^^ That is a bit of a problem when you have 3 pedals to the floor
Old Mar 24, 2008 | 03:06 PM
  #183
Blacksheepdj's Avatar
If you have 3 pedals to the floor, your car isn't moving and the motor is screaming at redline. All the while, your clutch is getting worn out from you standing on it. Not very effective...
Old Apr 24, 2008 | 09:12 PM
  #184
wanabeEvo's Avatar
thats funny because they really are doing it now
Originally Posted by Blacksheepdj
Not so much "bad shifting" shock but just the forces acting on the drivetrain. When you drop the clutch in a manual, you're putting a lot of stress on those gears. Maybe a tooth or 200 break off. What's the worst that happens in the CVT? Maybe the belt slips. See my point?
I can put my CVT in neutral and coast. And I can manually downshift to save brake pads too. You aren't selling me.
I'm not even engaging in any more CVT w/ turbo debates. I just ask that members not spread speculation and rumors as facts (you aren't, but a lot of people do). Until we see RRM boost a CVT, I'm just waiting and watching.
Old Apr 25, 2008 | 06:24 AM
  #185
Mark Hubley's Avatar
You're correct that the car isn't moving and the motor is screaming at redline. However, your clutch would not be getting worn out, as it would be completely disengaged from the flywheel. Standing on the clutch pedal would put some very small degree of wear/stress on the release lever, throwout bearing, and maybe the hydraulics, but not on the clutch
Old Apr 25, 2008 | 08:57 AM
  #186
RC2099's Avatar
Its really good thought to hear that someone has mastered heal-toe driving on the interstate! thats hard core! lol
Old Apr 25, 2008 | 10:33 AM
  #187
nunyas's Avatar
That depends on the throw out bearing. Not ALL throw-out bearings are roller type. There are a few throw-out bearings out there that are nothing more than a carbon faced friction plates, and standing on the clutch at a stop light will wear them out in a year or less. Granted, most (if not all) modern cars use roller type throw-out bearings these days.
Old Apr 26, 2008 | 08:02 AM
  #188
evo_soul's Avatar
lol god this has a legs and keeps going. CVT has a pulley system. You will remember that the pulley system has been mans greatest feets almost 5000 + years ago, they built pyramids with it, no small feet. A pull system is incredibly small. Heat is the only problem when it comes to pulley's or wenching systems. hense why there is so much fluid and a mini rad for the transmission.
In gear mode (manual) boost in theory should be relavant. the rope/cable/ what ever they are using for the rope lines, they have been rated to last a long time and to handle emense amounts of tension. HEAT is the only factor relavant that can really wear down or shorten the life of line. same for the dynamic pulley system.
A boost project to my knowledge I think is already out and about in japan. the only then they have banded the driver from doing is operating in continous variable mode AKA D mode.
Other then that, I think they are getting close to EVO spec boost without failure
Old Apr 26, 2008 | 01:22 PM
  #189
MasterAK's Avatar
So you think that the current CVT can handle the extra power without failing?
IMO we can speculate as much as we want but only time will show how much power can the CVT take.
NixK
Lancer Troubleshooting
Jun 5, 2017 04:06 AM
Newbee2015
Nov 2, 2015 12:46 PM
LuDa
Lancer Engine Tech
29
Sep 12, 2008 10:50 PM
evo_soul
Lancer Engine Tech
16
May 26, 2008 05:34 PM
DoHBoY
May 29, 2007 02:58 PM
