Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
ra gear swap into oz
Old Aug 13, 2007 | 06:48 PM
  #31
senate6268's Avatar
Originally Posted by Mirage2.0
And you are sure that it will work? How much it would shorter the gears?
Damn, alot of parts.
Yes it will work. The only difference between the two transmissions are 5th, the diff and diff gear. If you change to the RA final gear and diff here is what you'll see:
6000rpm speeds:
1st: 30mph
2nd: 55mph
3rd: 78mph
4th: 104mph
5th: 139mph
7000rpm speeds:
1st: 35mph
2nd: 64mph
3rd: 91mph
4th: 121mph
5th: 163mph
Punch in some numbers and see what you some up with:
http://www.f-body.org/gears/
Old Aug 13, 2007 | 07:42 PM
  #32
Mirage2.0's Avatar
Can you post some numbers for stock 4g94 for comparison?
Old Aug 14, 2007 | 10:00 AM
  #33
senate6268's Avatar
Originally Posted by senate6268
Yes it will work. The only difference between the two transmissions are 5th, the diff and diff gear. Here are the numbers with stock 4G94 tranny, diff and final gear:
6000rpm speeds:
1st: 32mph
2nd: 60mph
3rd: 84mph
4th: 113mph
5th: 151mph
7000rpm speeds:
1st: 38mph
2nd: 70mph
3rd: 98mph
4th: 132mph
5th: 177mph
The differences are subtle, but they are there.
jimbo74
16
Mar 6, 2024 02:46 AM
N1te
Lancer-Mirage Compatibility Forum
23
Jul 19, 2021 11:54 PM
rpm_ruffryders
Lancer Engine Tech
603
Mar 3, 2020 07:04 AM
Sheroku
Lancer Engine Tech
Mar 23, 2016 11:25 AM
turbotsi
Lancer Engine Tech
12
Jun 10, 2011 01:56 PM
