Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Gear ratio's
Old Jan 31, 2004 | 11:13 AM
AdamJ39's Avatar
Gear ratio's
I was looking for the Gear Ratios you guys got in your manual trans... can someone who knows them post it up...allong with the speedo readings at the top of each gear...also did you guys get the F5M41 Trans or the F5M42 Trans? I'm tring to compare...thanks
-Adam
Old Feb 12, 2004 | 02:08 PM
HobieKopek's Avatar
We have the same transmission as the Mirage, but I'm not sure about gear ratios. I used to have the info, but I can no longer find it (oddly enough).
Old Feb 12, 2004 | 02:10 PM
rhyzin's Avatar
gimme a sec...
F5M42
mph @ 6000 rpm on 195/60/15
1st ... 3.583 @ 31.8 mph
2nd ... 1.947 @ 58.52 mph
3rd ... 1.379 @ 82.63 mph
4th ... 1.030 @ 110.63 mph
5th ... 0.767 @ 148.56 mph
Final Drive...3.722
Old Feb 12, 2004 | 02:16 PM
Alchemist's Avatar
I was gonna say- just look for Rhyzin's posts in the PDA dyno thread.
Good work man
Old Feb 12, 2004 | 02:25 PM
Sonantoni's Avatar
I too....was searching for the gear ratios a while back, but couldn't find them
Old Feb 12, 2004 | 03:38 PM
rhyzin's Avatar
F5M42
Final Drive...3.722
Old Feb 12, 2004 | 09:27 PM
AdamJ39's Avatar
thanks guys...exactly what i was looking for...
-Adam
i was really wanting to compare the ratio's to the Mirage 1.5 Trans since those seemed like they would be better for the 2.0...so i maybe getting one...since its exactly the same aside from the Ratios...
Old Feb 13, 2004 | 11:09 AM
HobieKopek's Avatar
Adam, you're a madman! I love it!
I've never seen the 4g15 tranny. It's the same F5M42? Oh boy, this is making things interesting.
Old Feb 13, 2004 | 10:33 PM
AdamJ39's Avatar
just for you all to see...the 1.5 trans (Manual) F5M41
F5M41
1st- 3.583
2nd-1.947
3rd-1.343
4th-0.976
5th-0.804
VS
F5M42
1st- 3.583
2nd-1.947
3rd-1.379
4th-1.030
5th-0.767
so basically 1st and 2nd are oveously the same...but 3rd and 4th are longer and 5th is shorter....if you were talking MPH range...i would think that the 4G94 and G93 would get better responces from the F5M41 trans...the 4 door Mirage's with 1.8's came with the F5M41 trans while all the 2 doors got F5M42's....and i know some of the 4 doors guys have said they pull well...guess someone would have to try both to really find out for sure...hummm maybe that will be me
-Adam
Old Feb 22, 2010 | 07:29 AM
lancerguy0208's Avatar
Just wondering if anyone knows the top speed in gears for the '04-'06 Ralliart. I want to compare them to an '02 OZ Rally but I cant find them anywhere. I know the ratios but not the max speed at redline in each gear.
Old Feb 22, 2010 | 08:01 AM
senate6268's Avatar
Ralliart (6500rpm on 205/50/16 tires):
1st - 3.583 - 32 mph
2nd - 1.947 - 59 mph
3rd - 1.379 - 83 mph
4th - 1.030 - 111 mph
5th - 0.820 - 140 mph
Fin - 4.04
Old Feb 24, 2010 | 08:18 AM
Originally Posted by senate6268
Ralliart (6000rpm on 205/50/16 tires):
Fin - 4.04
I just want to clarify for myself, you say these speeds are at 6K. The Ralliart redlines at 6500. Did you make a mistake or would the speeds at redline be higher than these?
Old Feb 24, 2010 | 08:54 AM
Z_Lancer_Man's Avatar
Yes, if you rev to 6500, then the speeds will be higher, assuming his 6000 RPM isn't a typo.
Old Feb 24, 2010 | 09:28 AM
senate6268's Avatar
That was a typo. The speeds noted were for 6500. I corrected my post.
electron bom
Sep 30, 2016 09:53 AM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
Nov 23, 2010 09:57 AM
adammartini
Dec 21, 2009 07:07 PM
Tractionlimit
12
Jul 26, 2009 02:15 PM
DynoFlash
35
Mar 20, 2008 08:25 PM
