Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Automatic Transmission...weird sound
Old Sep 17, 2002 | 01:43 AM
OZ_Rally's Avatar
I have a Auto transmission and when I back up and then shift into drive and step on the gas the left front tire makes a small pop noise. No I do not do nuetral drops,power braking or any other destructive act on transmissions.
Thank You
Old Sep 17, 2002 | 01:44 AM
Kurt's Avatar
Best bet would be to take it to your dealer and have them look at it.
Old Sep 17, 2002 | 01:53 AM
HobieKopek's Avatar
When in doubt...take it to the dealership and play dumb (if you caused the problem that is).
Old Sep 17, 2002 | 02:20 AM
OZ_Rally's Avatar
for once I can honestly say "I didnt do it."
Old Sep 17, 2002 | 04:02 AM
JohnMemorialHS's Avatar
what's power braking? I'm dumb, I appologize. As for transy drop, how bad is it for the automatic transmission. My friend has a 2001 eclipse, and he does that all the time, I told him it's bad for the transmission, but he wouldn't listen. How many transy drops can you do before you wreck your transmission?
Old Sep 17, 2002 | 04:11 AM
OZ_Rally's Avatar
depends...but it is bad...lot of times if you are lucky it will just snap or pop out yore torque converter/flywheel bolts. It can even trash first gear totally...tell the uneducated one to stop, or his eclipse will soon eclipse the front lawn as a ornament.
lol
later
Old Sep 22, 2002 | 07:14 AM
I don't care if he trashes his 2001 eclipse gs, stupid 3rd gen. eclipses, wish they'd bring the 2nd gen. back, can't stand those wavy doors.
Old Sep 24, 2002 | 10:13 AM
bahamut's Avatar
Power braking and neutral drops are totally different things.
N-drops tear your auto tranny to pieces the fastest. Hold revs in N and drop into gears. Column shifting like a manual also tears up your tranny too. Both sound fast but ineffiecient.
Power braking. Holding the brake and gas at the same time. You can only do it for a short period (under 4 sec), or your TQ converter will burn up from lack of tranny fluid circulation.
Old Sep 24, 2002 | 10:14 AM
bahamut's Avatar
Re: Automatic Transmission...weird sound
Thank You
you're shifting too fast before the ecu can properly tell the tranny to shift in gear.
Old Sep 30, 2002 | 10:02 PM
OZ_Rally's Avatar
is that what that is...i never noticed it before...but with a 100watt stereo system(first one I ever had) I dont exactly drive in complete silence.
now keep in mind it is not a popping noise like screeching tires..but like on a older car when you have a mad transmission mount,whichis what im afraid of. but it is a small pop and it is noticeable.
I was thinking about getting the LSD front end at tax time...which will void my power train warranty. but if I take it in and they dont want to fix the noise if it is something bad...the lsd might be a good choice.
I hope it does not come down to that.
AJCaron12
27
Jul 18, 2015 11:02 PM
Beluga
Apr 24, 2014 04:42 PM
peanutboylancer
May 9, 2011 10:21 AM
spyder526
South Region
16
Jan 14, 2009 08:49 AM
althekiller2
Aug 24, 2007 01:50 PM
