SRI blew off the intake manifold??
Old Jun 3, 2005 | 10:39 AM
bettorer's Avatar
i gunned it and my intake blew right off the throttle body. i diddn't know at first and tried driving it but the car would rev up then die. i did that a couple times before i decided to check under the hood. could this have caused any serious damage. is there anything i should do?
Old Jun 3, 2005 | 10:48 AM
Archangelite's Avatar
no, just reconnect the sri and make sure you tie it real tight. thats why it blew off in the first place. disconnect your battery for 5 mins. then connect it, start your car and let idle for exactly 15 minutes.
Old Jun 3, 2005 | 10:52 AM
gregivq's Avatar
WOW, it's really not cool. Someone told me if this would ever happen to me it would destroy my engine.
You should check your plugs. Since your MAF was disconnected your ECU did not know how much fuel to add. Maybe you were lean or rich who knows. If the tips of the plugs are white then you were lean. If you think your engine was very hot (running lean) then you could have damaged the gaskets from intake manifold.
This is the only knowledge I got about this problem. It happened to my friend's eclipse.
His gasket blew up from the IM.
Old Jun 3, 2005 | 03:21 PM
clovis112's Avatar
who installed your sri? you should go back to them...
Old Jun 3, 2005 | 03:24 PM
HobieKopek's Avatar
The MAF would tell the ECU that it's got virtually no air moving through it. If the ECU is smart it'd realize something was wrong and immediately throw the car to full rich...but I don't know if that's the case. Reconnect it, and if everything feels fine...everything's almost definitely fine. The chances of something catastrophic happening are pretty slim, and the effects would probably have been immediate.
zlancer's Avatar
its not really that bad of a thing. the computer can compensate when something like that happens. just tighten the clamps and do what Archangelite said.
Old Jun 3, 2005 | 03:25 PM
smokin_oz03's Avatar
how long was it off?
Old Jun 3, 2005 | 03:26 PM
zlancer's Avatar
jus FYI....i ran my car for like 2 weeks with the MAF disconnected (long story) and nothing bad happened. Just ran rather rich.
Old Jun 3, 2005 | 03:32 PM
HobieKopek's Avatar
Then I guess the ECU does know enough to throw it into limp mode. I'm sure that's reassuring for you MAF people with cars that...you know...run and stuff.
Old Jun 3, 2005 | 03:33 PM
Alchemist's Avatar
you guys remember BOOYAH1369? He ran with, get this, dryer hose clamped directly to his TB, with pantyhose for a filter, for a week or something. No MAS, no filter, just the dryer hose. Said he was getting 6MPG but making "mad power" When he put everyting back the car ran fine.
You'll be ok
Old Jun 3, 2005 | 03:43 PM
You'll be ok
ghetto as hell
Old Jun 3, 2005 | 07:57 PM
bettorer's Avatar
haha. k phew. after it blew off i drove for like 30 secs before i realized something was f-ed. i left it off over night cause i was heading to the bars and reconnected it in the morning. The CEL was on for like 30 min then it went off and seems to be running fine.
oh and i put it on myself
Old Jun 4, 2005 | 03:47 AM
Slovak's Avatar
You'll be ok
Now that's funny as hell
Roginald
Aug 13, 2015 09:05 AM
foxmr
15
May 20, 2010 04:55 PM
evolancer04
Sep 1, 2008 04:58 PM
EVIL_EVO_VIII
Sep 30, 2007 08:40 PM
MrBonus
51
Aug 10, 2004 08:14 PM
