Cat Bolts
Old Jun 24, 2005 | 04:45 PM
mitch44759's Avatar
Question Cat Bolts
Hi Guys, I just got my magna flow cat back system in today, so i was all excited well when i went out to install it i noticed the bolts on my stock cat are rusted so bad that the threading is gone, (believe it has never seen a snow fall). but my queston is are the bolts on the cat replacable if i just brake them of and if they are replaceable can i pick them up at a local auto zone or parts america? Any help would be greatly appreciated.
Old Jun 24, 2005 | 07:25 PM
oz4g94's Avatar
you will more than likely need to use some pliers and remove the bolts from the cat, im pretty sure that they are threaded into the cat flanges. i have done my headers and cat-back, and as far as i can remember they are threaded into the cat. but you should be able to pick some up a local auto shop. definitely do not cut the bolts though, it will make it very difficult if it is threaded into the cat. good luck.
Old Jun 24, 2005 | 10:13 PM
kevin_stevens's Avatar
Agreed, look closely at the front, they're either threaded in or they're studs (can't remember but threaded sounds right). Hit 'em with some Kroil for a couple days before, maybe heat with a torch. My car had only 5K miles and the nuts/threads looked pristine, but it took a *lot* of force to break the nuts loose. Torque spec on them is only like 40 ft-lbs!
KeS
Old Jun 25, 2005 | 01:47 AM
Slovak's Avatar
They are threaded into the cat, but youi can't remove them, just put some *** into it and kroil, or pb blaster and have at it. If anything, just cut the nuts off with a torch or dremel and cutting wheel., not the whole bolt.
Old Jun 25, 2005 | 09:19 AM
mitch44759's Avatar
Why cant i just cut the bolts drill them out and put my own in there for the time being, i am planning on putting in the magnaflow hi flow cat in soon any ways.
Old Jun 25, 2005 | 09:32 AM
SLVROZ_03's Avatar
Cut them off if you'd like. By brother ended up braking all of his on his rusted cat and downpipe ('98 Integra from MI). His bolts used a spring between the to pieces, but I'm really in the dark with the Lancers. Any bolt with a locking nut will work, if that is applicable on our cars.
Old Jun 25, 2005 | 09:36 AM
GreenPsycho's Avatar
they might look bad, but wd40 them or similar for a good 6 hours before hand (repeatedly, give them a good soaking).
then just use a breaker bar or impact wrench if you have one (might be worth it to rent it from home depot or something)
if all else fails, have a shop put it up on a lift and take them out
Old Jun 26, 2005 | 03:36 PM
mitch44759's Avatar
Allright i took it to a shop they heated them up and backed them out, I then went to value baught a few stainless steal bolts and put them on fits perfectly. Thanks for all your help.
VMC216007
Apr 12, 2015 06:48 PM
saytheb
May 31, 2012 11:27 PM
Gotum209
Lancer Troubleshooting
10
Apr 10, 2011 08:51 PM
04Evo851374
Apr 7, 2011 04:29 AM
OhSixLancer
Mar 30, 2011 02:56 PM
