Throttle issue
Old Jun 29, 2005 | 09:02 AM
blaze_125's Avatar
Throttle issue
If you guys have any suggestion before I get my baby under the wrench, let me know. So here's the deal.
While I'm driving, every once in a while when I let go the gas pedal, when I get back on it the pedal is freakin stiff like hell. I rev the car a few time opening the throttle a maybe 20% and then the pedal feels normal again. That can happen 3-4 times on a 30 minute drive. I've been experiencing that since it's cooking hot down here(if that makes a difference).
Old Jun 29, 2005 | 09:06 AM
HobieKopek's Avatar
Probably a minor kink in the throttle line. I guaranteed it'd be either in the engine bay (maybe if you've ever removed it there was occasion for it to be unintentionally bent severely) or where it sits along the firewall.
If not, you can make sure the motion on your throttle body is ok. There could be something sticking there, or the spring could have somehow bent.
Old Jun 29, 2005 | 09:22 AM
blaze_125's Avatar
That is actually my main concerned... I cleaned the K&N recently and took the opportunity to clean the oil buildup in the TB, so I'm arfraid I might have moved something in the process. I haven't touched the Throttle cable since last year though when I move the plate a little further for a somewhat "better" throttle feel.
Old Jun 29, 2005 | 10:03 AM
HobieKopek's Avatar
Try putting more slack in the line by putting the plate back. I don't know if that'll help, but it only takes 30 seconds, so it's worth a shot.
Old Jun 29, 2005 | 03:31 PM
bobaab's Avatar
if it's stiff, moving that plate wouldnt help in my opinion...
maybe when you were cleaning the TB you touched something? try messing with it again to see if anything is loose or something.
Old Jul 4, 2005 | 06:16 AM
blaze_125's Avatar
Allright... found my problem:
On the Driver side under the steering column there is a Duct for Heat/AC. That duct came loose and was leaning against my gas pedal
Old Aug 1, 2005 | 06:14 PM
PGDlancer's Avatar
that is hilarious
Old Aug 1, 2005 | 07:20 PM
datdjrobp's Avatar
here's your sign... lol
Old Aug 2, 2005 | 11:36 AM
blaze_125's Avatar
Yep
SoloSpeed101
May 23, 2023 10:34 PM
mnewdigate
Lancer Troubleshooting
10
Apr 24, 2016 11:25 AM
caideN
Feb 18, 2015 05:05 PM
18bora
Nov 7, 2011 11:05 AM
EvoDaWayToGo
Apr 18, 2005 04:15 PM
