Opened fuel pump to check install then reinstall now wont start!!!!
Old Jul 1, 2005 | 12:26 PM
Kelspar's Avatar
Ok new news! check it; remember how i tested the flow? well i took stock fpr off and fuel gushed when i turned it through the open end of fuel rail. well i put stock fpr on and the line that comes off it (fuel line not vaccume) is dry as a whistle when i try to turn it over. is this normal?
Old Jul 1, 2005 | 12:28 PM
Kelspar's Avatar
Originally Posted by Handmemyarms
good thing you did it before work
ya lol i told em im not coming today, i dont care anyway i do all the damn repairs at the shop anyhow. they can deal with it. havent had a day off in 2 weeks!
Old Jul 1, 2005 | 12:43 PM
HiHeatEVO's Avatar
this is totally outside of the scope of my expertise. if it's a fuel line i would imagine it SHOULDN'T be dry. man i'm off work so..good luck
Old Jul 1, 2005 | 12:48 PM
Kelspar's Avatar
I called rrm (again) and the guy i talked to was like......uh... let me have someone call you back and he took my number. So i guess ill just reasseble everything and then wait.
Old Jul 1, 2005 | 02:28 PM
Kelspar's Avatar
I think its the stock fpr im not sure....but mitsu tells me 80 for a new one.... =( IT WAS WORKING YESTERDAY!
Old Jul 1, 2005 | 03:18 PM
Kelspar's Avatar
Ok here is what i discovered; please correct me if you think my assumtion is wrong (it would save me about 80$). Problem is that car will not start; when it does it stay idleing for ~7 sec. Then violently chokes to death (probably lack of fuel). Well i tested fuel pump; i disconnected the inlet side of fuel rail, i get fuel spilling all over the place when i turn it over, which obviously means the pump is pumping. Ok well i reconnect then goto other side of fuel rail (with stock regulator). Well i take regulator off and turn it over; i get fuel spilling out of the fuel rail, once again the fuel pump is working up to this point. Ok well i reattach stock regulator and disconnect fuel line that is connect to it. Then i turn it over......nothing, dry as a whistle. So from this can you also conclude that it is my stock fpr that is bad?
Old Jul 2, 2005 | 06:47 AM
SLVROZ_03's Avatar
This exact problem was just discussed in another forum. Check out the problem here ( https://www.evolutionm.net/forums/sh...d.php?t=146755 ). The answer proved to be that the return line needed to be blown out. But check it out.
Old Jul 5, 2005 | 06:46 AM
Kelspar's Avatar
That was my thread and Rhyzin helped me figure it out, im so greatful!
Old Jul 5, 2005 | 07:07 AM
initialDRacer's Avatar
kelspar, I'm sorry that this is happening to you. You should solve this problem within a day or two because this is your daily driver and you don't want it getting in the way with your work. Obviously it already has. After two days have gone by and you haven't fixed the problem, it might be wise to just remove the whole thing and find out if the problem is the turbo or your car. If you don't you'll just have too many headaches coming to you in the not so distant future, not to mention wasting your money.
Bloomie
10
Jan 28, 2024 09:31 AM
Kris86
May 22, 2017 10:53 PM
xceler8rob
34
Jul 17, 2016 12:57 PM
Raheelq
AEM EMS
11
Jan 15, 2010 09:23 AM
Racer1
Feb 28, 2005 08:32 PM
