help Cel light came on last night
Old Feb 27, 2006 | 12:45 AM
joshthegreat's Avatar
ok thanks for the help, i will do that step by step and update u on the results
Old Feb 27, 2006 | 06:16 AM
Boeturbolancer's Avatar
First off... 2 step colder on the plugs is a must with the lancer motor. Higher compression.
Next and before you ever boost again get a compression check done. If you are still getting the misfire code chances are you've hurt a piston and the dings on it from detonation are creating hot spots.
Next: list what you have on the car in detail.
Specifically, Fuel management, fuel pump, what boost your set at, etc. From there i can assist more but it doesn't sound good to me.
Old Feb 27, 2006 | 06:55 AM
comatose721's Avatar
wow. 2 steps colder. i did not know that! i didn't get to compression testing yet cause i wanted to start simple.
but boy am i glad boe is here
Old Feb 27, 2006 | 07:57 AM
High compression + high boost makes for a very hot chamber... the colder plug ensures you don't get the ground so hot it ignites the fuel prior to spark.
When this occurs you usually end up with a spark plug that has a burnt off ground.
Old Feb 27, 2006 | 09:50 AM
ok fuel wise im running the fmu that came with the tsi kit, which i think is 14:1, with the bored out fuel rail, and stock pump. boost is set at 6 psi
Old Feb 27, 2006 | 09:56 AM
gregivq's Avatar
^Wow, shouldn't you be using 255lph pump?
Old Feb 27, 2006 | 10:40 AM
impetus19's Avatar
i think you could get away with a 2g turbo eclipse fuel pump which is 190lph. But there is no way the stock pump can handle the boost.
Old Feb 27, 2006 | 11:09 AM
Stock pump and boost= booooommmm!!
Definately get that compression checked... DON'T boost on the stock fuel pump... change that out to a 190 or best 255lph.
Old Mar 4, 2006 | 12:36 PM
ok update guy, im towing the car to my friends speed shop, they are gonna ripp apart the motor and rebuild it forged pistons and rods, along fuel pump injectors intercooler and piping, is there any other weak part of the motor i should beff up while its all torn down
Old Mar 6, 2006 | 10:18 AM
pistons and rods are weakest. Crank hasn't broken yet so it's plenty strong. If your gonna have it all apart and out i'd do a lightened flywheel and upgraded clutch.
That way you don't have to pay for the install later.
If you can get the head ported and polished... turbo car loves that. If you plan to go big boost later then get ARP head studs.
Old Mar 8, 2006 | 03:18 AM
awsome, yea head is getting ported and polished also, apr studs are a must, my girlfriend is helping me buy all this this, its awsome, i should have a monster when its all done
BrownSuga
Apr 27, 2016 10:18 PM
ModifiedMR
20
May 17, 2010 12:14 PM
turbo06evo
16
Jan 6, 2010 04:18 PM
eponti
18
Sep 30, 2006 02:55 PM
Wangan_X
Jan 23, 2004 10:33 AM
