Ah I broke a screw!
Old Apr 20, 2006 | 04:49 PM
mtags24's Avatar
Ah I broke a screw!
When I was changing my base bushing i snapped the top right screw in half. So now the other half of the screw is screwed into the base and the other half is in my hand. It still shifts ok and there is only a little bit of movement in the shifter cage. Am I going to be alright? How could i possibly fix this? Or am I screwed?
Old Apr 20, 2006 | 04:58 PM
ambystom01's Avatar
You might wanna get that fixed, I'm sure the dealership could solve it for you.
Old Apr 20, 2006 | 05:03 PM
SLVROZ_03's Avatar
Tap it, and back it out...
Old Apr 20, 2006 | 05:11 PM
mitsuozboi's Avatar
+1
thats really all you have to do. Its fairly easy, you just need the tools.
Old Apr 20, 2006 | 07:42 PM
mtags24's Avatar
Thanks for the help so far guys. Ok so how would I do this? It's really hard to get under the screw where it is positioned
Old Sep 24, 2006 | 09:14 AM
tbsfan53187's Avatar
Question the other day on the 5...
my car crapped out, the clutch still has pressure and you have to push it in to start the vehicle, but the shifter freely moves through the gears without making any noise or shifting the transmissions gear. Is there a cable or linkage that connects the shifter to the transmission?
Old Sep 24, 2006 | 10:11 AM
Blacksheepdj's Avatar
Yeah, there's two. One handles the left-right action of the shifter, the other does the front-back motion.
Old Sep 25, 2006 | 12:57 AM
sykou's Avatar
I think one of the cables must've come off. Your shifter is just moving around freely, it seems
Old Sep 25, 2006 | 01:51 PM
mtags24's Avatar
Wow I can't believe I didn't come back to this thread and say what i did. I went in and removed the metal base of the entire white shifter assembly. It was not too hard to get the piece of screw out after that.
For your problem it seems that something came loose that connectes the shifter to the transmission. it is done through two cables (i think) and has two connections to control the front back/ left right movements of the shifter as blacksheepdj said. i would take apart the center console and check to see if something simply came loose as opposed to snapping or breaking. good luck!
EvoTamer
Aug 10, 2009 09:04 PM
MitsubishiMan18
Lancer How Tos / Installations
Jan 23, 2009 06:57 AM
silver evo8
Jan 22, 2009 02:12 PM
ShtrMcGavin
Nov 5, 2006 10:41 AM
