Air conditioning leak? (need help)
Old Jul 15, 2006 | 06:13 PM
lancerman360's Avatar
Ok so when I am going around corners, slowing down real fast, and accelerating real fast <(ha yeah right) with my air on I can hear this noise comming from behind my glove box. I cant really explain how it sounds but its kind of like a low pitched hissing noise. The thing is now there is water dripping from under my glove box. Its pretty much a constant drip- my sister just took my car for a drive while I rode in the passenger seat and the watter drip is pretty bad and I dont know where it is comming from. Everything looks ok under the hood, and my car stinks now because of all the water. If anyone has had a problem like this please let me know what is wrong, I am not under warranty so this is not good. I will try to not use it until I find out what is wrong but its real hot down in texas so that might not last long.
Old Jul 15, 2006 | 08:20 PM
BigP436's Avatar
the evaporator drain line is clogged.. if you take it to the dealership they are well aware of the problem, its a common one.. should run you about $30-40.. unless you want to tackle it yourself and save some loot.
Old Jul 16, 2006 | 09:31 AM
Thanks a lot. Thats a big relief. How would I be able to clean it out? I am all about saving money.
Old Jul 16, 2006 | 11:43 AM
kott_tot's Avatar
i had th same problem last summer, i took it to goodyear and they said there was a hole in the bottom of the car that is the drain for the ac and it gets clogged, but they couldnt find it so they sent me to an ac shop, 30 min and 20 bucks, no more problem
Old Jul 16, 2006 | 08:38 PM
Thanks a lot guys. I will check it out tomorrow.
Old Sep 22, 2007 | 01:12 PM
HornstarBU's Avatar
I posted 2 pictures here that might help
https://www.evolutionm.net/forums/sh...ght=evaporator
03blkevo
Jul 15, 2009 01:08 PM
H'swwEVO
Dec 16, 2008 12:02 PM
W_evo8
Jun 27, 2008 02:11 PM
Blacksheepdj
Lancer How Tos / Installations
Apr 24, 2008 03:33 PM
aceinthesky2002
12
Jan 7, 2008 03:52 PM
