I think the blower motor may be going...
Old Jan 7, 2007 | 02:46 PM
Wallesasuaz's Avatar
Yup...
Told you it was expensive. And that's not even including the labor.
Old Jul 16, 2008 | 08:11 AM
jody-z's Avatar
Did anyone ever get to the root of the problem? We're having the same issue ourselves.
Old Jul 16, 2008 | 08:50 AM
Nope. Surprised this never became a recall.
Old Jul 16, 2008 | 09:22 AM
jody-z's Avatar
Well, I'm of the conclusion that the blower resistor keeps failing due to a faulty blower motor, which is drawing too much current, causing the blower resistors to die. Just wanted to see if anyone could verify and speed-up my trial-and-error process.
Old Jul 16, 2008 | 11:11 AM
Walkingchaos's Avatar
yes its either a bad resistor or a motor which is causing the resistor to blow.
Old Jul 16, 2008 | 05:09 PM
Miira's Avatar
I'm having same problem. In my case, I think the AC drain was plugged, which caused condensation water to back up into the blower motor(and onto my passenger side floorboard). The water caused the blower motor to sieze, which caused the resistor to blow. I replaced my blower motor last fall. After I replaced the motor, the fan only worked on setting 4, it had worked fine until the motor blew. I ignored the fan only working on 4, because at least it worked. This summer when it was finally warm, I noticed the AC problem. I have ordered the new resistor ($117) and I will pick it up tomorrow. I haven't been able to find where the resistor is by searching online. I assume its somewhere behind the passenger side dash. I will let post again and let everyone know how it went and where that resistor is for those of you that want to fix it yourselves.
Old Jul 16, 2008 | 05:13 PM
Miira's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=175469
Please read that thread (its stickied). It will tell you how to unclog the drain to prevent future problems. There are even pics posted to show you exact location of the drain.
Old Jul 22, 2008 | 04:58 PM
getsideways's Avatar
https://www.evolutionm.net/forums/sh...lower+Resistor
Here it is.
Old Jul 24, 2008 | 09:42 AM
how about that.
oh well.. should come in handy if the problem ever arises w/ my evo.
Old Jul 24, 2008 | 09:56 AM
jody-z's Avatar
CONFIRMED...my blower/motor was starting to rust, which was causing it to draw too much current, causing the blower resistors to die. Problem solved.
jdrames
Lancer Troubleshooting
Mar 25, 2021 10:35 AM
josephatgts
Sep 18, 2016 02:23 PM
zieg08
Aug 17, 2011 07:44 PM
bowlofturtle
20
Nov 2, 2009 03:48 PM
icedomin8r
Aug 13, 2006 04:47 AM
