RRM Header Problem
Old Mar 24, 2007 | 07:41 AM
Kamikaze978's Avatar
RRM Header Problem
I just installed my RRM header yesterday and had basically no problems. Only one was that i couldn't reattatched the header to the body to stabilize due to different size of bolt and the fact that they don't quite line up. Anyway, after my install I had the usual smoke and smell, but it also doesn't sound right. I can hear the deeper sound from it but there is also a higher sound that just doesn't seem right. My only other engine upgrade is the RRM intake. I'll try to post some sound clips as soon as I can but does anybody have any idea's on this? I have triple checked to make sure all nuts are tight as I can get them...
Old Mar 24, 2007 | 07:59 AM
mtags24's Avatar
can you post any pictures?
Old Mar 24, 2007 | 11:54 AM
grapeapeoftokyo's Avatar
what did your gasket look like? as ive never installed the rrm header i dont know what it comes with(ie new gasket,bolts etc.), did you install the gasket properly?
Old Mar 24, 2007 | 12:15 PM
ambystom01's Avatar
It doesn't come with gaskets or bolts if I remember correctly. The smoke is normal and the sound is probably normal too. Not sure what you mean by attaching the header to the body, can you clarify that with pics?
Old Mar 24, 2007 | 03:02 PM
http://s176.photobucket.com/albums/w...Picture140.jpg
http://s176.photobucket.com/albums/w...Picture141.jpg
http://s176.photobucket.com/albums/w...Picture143.jpg
and under...
http://s176.photobucket.com/albums/w...Picture142.jpg
I have one side bolted in but the other side doesn't fit and I was told that my exhaust is shaking from behind when I drive... but it doesn't sound like it is hitting anything...
Old Mar 24, 2007 | 03:16 PM
ambystom01's Avatar
The exhaust shaking is probably normal, exhaust gases are flowing faster now so they have more force to them. The downpipe bolt is kinda weird, I think mine bolted on without a problem.
Old Mar 24, 2007 | 06:20 PM
ThunderOZ's Avatar
my exhaust is still stock for now and it shake from behind...
Old Mar 24, 2007 | 07:08 PM
K, so i'm sitting here thinking and I remember that one of the split washers that attatches the header to the exhaust was opened up a little more than the other. Anybody know if that could be letting in out out some unwanted air?
Old Mar 24, 2007 | 07:13 PM
ambystom01's Avatar
If you let the car idle for a while, does the engine bay smell of exhaust fumes? That's one way to find out if there's a leak.
Old Mar 24, 2007 | 07:22 PM
atilla's Avatar
as far as position goes... i wouldn't worry about the bolt. i did not attach it on my car and i have had no issues. the sound is also normal--my car took on a much higher pitch when i put the header on. you'll get used to it.
the split washers shouldn't be causing a leak... if you had a leak it was because of the gasket. if your gasket is bad there will be a exhaust leak. the gasket does the sealing, not the washers.
Old Mar 24, 2007 | 08:23 PM
Alright cool, thanks a lot. Guess I'll break down and buy a new gasket ( a whole 5 bucks or so?).
Old Mar 24, 2007 | 08:25 PM
ambystom01's Avatar
It's like 19 bucks I think.
gui dube987
35
Feb 13, 2014 12:09 PM
gary_06ralliart
Oct 26, 2010 07:14 AM
Gr33dyMitsU
Lancer Engine Tech
10
Apr 20, 2007 09:27 AM
sykou
Dec 14, 2005 07:53 PM
LancerOZ
Lancer Engine Tech
Aug 30, 2004 08:40 PM
