04-06 Ralliart Engine/Drivetrain (no forced induction)
Header/downpipe install ?
Old Oct 7, 2009 | 05:22 PM
gary_06ralliart's Avatar
With the obx or rrm header and down pipe combo is there any welding involved?? from the pic it looks bolt on, but it doesn't seem like the down pipe is long enough or has the right bends to get to the axle. thats the only place i see another flange besides the header. thanks for any help guys!!
Old Oct 7, 2009 | 06:49 PM
soulesswarrior's Avatar
the header/dp is all bolt on. it DOES NOT lead to the axel. it leads to where the cat bolts on. UNLESS your cat is not bolt on. if it is not you will have cut and weld.
Old Oct 7, 2009 | 10:29 PM
Raikiri's Avatar
he has an 06 RA though. the header/dp will bolt on and will actually eliminate your cat unless you buy a high flow cat to weld in but will bolt onto the exhaust piping
Old Oct 8, 2009 | 08:52 AM
yes it is the 06, and i see that it elminates the cat, but it doesn't look like my cat is bolted on, i think its welded, i'll check again today be sure, but its supposed to just bolt up right after eliminating the cat? thanks again guys, i just want to be sure before i purchase
Old Oct 8, 2009 | 08:54 AM
yes its supposed to bolt to the flange right after the cat. so if you have a welded on cat you will have to cut out the cat and throw on a flange. id also reccomend rrm over obx.
Old Oct 8, 2009 | 11:28 AM
Raikiri's Avatar
a welded on cat? did something happen to the oem one? if everything is stock on the car the cat should already have a flange that bolts to the exhaust piping. that just needs to be removed. i also would recommend rrm over obx
Old Oct 8, 2009 | 12:04 PM
i think the 06 ralliarts came with weld on cats.
Old Oct 8, 2009 | 05:27 PM
Silverbolth's Avatar
Well I have an '06 ralliart and it does have a flange after the cat...
Old Oct 26, 2010 | 07:14 AM
rj88's Avatar
i need one
floating doc
Jan 18, 2017 11:29 PM
helgusmc
Dec 7, 2010 05:05 PM
EyeDreamt
Lancer Engine Tech
Oct 30, 2010 07:06 AM
reimundo
Nov 21, 2005 08:35 AM
Nero
Lancer Engine Tech
10
Dec 16, 2003 09:15 PM
