headlight flickers when driving...
Old Apr 13, 2007 | 10:00 PM
lilazn64's Avatar
So this problem just recently started.
My left (driver's side) headlight turns on and off randomly when I'm driving and I don't know what's causing it. There is no pattern. Doesn't matter if I hit bumps or not. It just randomly turns on and off.
I checked the harness to see if it was loose and the wires to see if they were in place or not, but everything seems fine. If I drive with the high beams on, they stay on all the time. The normal low beam lights are the only ones that will turn on and off randomly.
Anyone seen or heard of this problem before? Any help?
Old Apr 13, 2007 | 10:03 PM
trueno429's Avatar
try changing the bulb
Old Apr 13, 2007 | 10:15 PM
sikrsix's Avatar
swap the bulbs.. its free and youll know if its wiring or the bulb depending on what happens next.
Old Apr 14, 2007 | 01:21 PM
03_Lancer_ES's Avatar
also check the connections
Old Apr 14, 2007 | 11:19 PM
lilazn64's Avatar
thanks i'll get right on that.
Old Apr 15, 2007 | 06:35 AM
Myszkewicz's Avatar
Probably one end of the low beam filament is loose. When it touches, the light is on. Vibrations knock it loose again, and it goes off.
Swap bulbs.
Old Apr 15, 2007 | 06:39 AM
hksevoix's Avatar
^+1
Old Apr 15, 2007 | 08:35 AM
lancer2show's Avatar
this happened to me too. i had to hit the headlight and it fixed the problem.
Old Apr 15, 2007 | 09:29 PM
^ When all else fails, just hit the damn thing haha
Old Apr 16, 2007 | 09:17 PM
lilazn64's Avatar
well it's not the bulb. so i'm guessing it's the harness. wire might be loose somewhere...
actually i have and that's what actually fixes it most of the time. lol
lancer02Josh
Lancer Troubleshooting
Aug 5, 2020 10:17 PM
cts4g63
Apr 11, 2016 08:32 AM
VR4Babe13
10
Feb 23, 2015 08:47 AM
Mochiman
Dec 19, 2010 08:01 PM
gallas
Feb 14, 2009 10:19 PM
