IMPORTANT - 2008/2009 Lancer window tint problem
Old Jun 27, 2007 | 05:33 PM
  #91
cruzzrr's Avatar
My windows are finally re-done... so far now more scratches.. but now I have glue smears on the windows - what do you recomend to remove this from the tint?
Thanks!
Old Jun 27, 2007 | 07:29 PM
  #92
Bradley_J's Avatar
Lacquer Thinner does the trick
Old Jun 27, 2007 | 07:36 PM
  #93
cruzzrr's Avatar
Won't that eat away at the tint???
Old Jun 27, 2007 | 08:02 PM
  #94
Kwelity's Avatar
Thanks!
Where did the glue come from? Is it something the installer did or the result of something you did? If its the installers fault make him clean it up.
Old Jun 28, 2007 | 04:50 AM
  #95
08Lancer89's Avatar
googone ^^^
Old Jun 28, 2007 | 08:49 AM
  #96
LANCER GuTS's Avatar
cruz, unless you want to have your windows retinted, I would not us Brad J's advice by cleaning the glue with Lacquer Thinner. Try using an aerosol based cleaner without ammonia. Actually any glass cleaner without ammonia should work. Ammonia will eventually cause the glue to delaminate. Tint is very porous(sp?). Hot water and dish soap would also work. Spray the cleaner on the glue and rub it with your fingers to break up the glue and wipe it off with a soft towel.
Old Jun 29, 2007 | 10:53 AM
  #97
08Lancer89's Avatar
or use eagleone 20/20 glass cleaner its safe on tint, its what I used when I detail cars!
Old Jun 29, 2007 | 12:54 PM
  #98
chino ali's Avatar
Originally Posted by Blacksheepdj
Small moose in driver door cupholder, Boo plushie in backseat middle cupholder.
It'll be the signature 08 thing.
Plus a plush Florida Gator sounds pimp.
Florida Gators, DJ!
FTW
Old Jun 30, 2007 | 10:41 AM
  #99
MaRcO_GTS86's Avatar
So far, I haven't had any problems with my tints (knocks on wood) I got them done from a friend of a friend, and he told me not to roll the windows down for at least 3-4 days, and to not clean them for at least a week. I waited about a week before I rolled them down, and about 10 days before I actually cleaned them. So I'm not exactly sure why others tints are scratching or peeling, but it's possible that maybe you didn't wait long enough, or they were installed wrong?
Old Jun 30, 2007 | 11:05 AM
  #100
chetman7's Avatar
^^ just wait....if the guy didn't put the felt on the weather strip. ur bound to get scratches.
wd40 has many many uses...one of them being it removes and loosens glue residue
Old Jun 30, 2007 | 02:58 PM
  #101
08Lancer89's Avatar
Yep you will get them sooner or later, I made sure I got the Moleskin put in the frist time, I have no problems with mine, becasue of it... Doing it right the frist time!
Old Jul 2, 2007 | 07:28 PM
  #102
cruzzrr's Avatar
I know WD40 would work, but afraid it may eat through the tint also???
Old Jul 3, 2007 | 04:59 AM
  #103
chetman7's Avatar
^^ I would think there would be harsher chemicals in window cleaner then wd-40.
Can anyone confirm that wd-40 will eat through tint caus eI will then stop using it
Old Jul 4, 2007 | 05:34 PM
  #104
08Lancer89's Avatar
Don't know but I do know that AmorAll on plastics is not good, after so many years your plastics will turn white!
Old Jul 4, 2007 | 06:42 PM
  #105
rvk778's Avatar
My tint story:
1. took car into detailer
2. detailer told me right off the bat i would need moleskin
3. waited 5 days before rolling one window down
4. glue showed up on the tint
5. moleskin came off
6. took car back in to get it looked at. they fixed it. repeat steps 1-5
7. detailer then found a better way to apply the moleskin and now I haven't had any issues *crossing-fingers*
