brake lights problem, fuse or bulb?
Ok, Here's the deal. My passenger side tail light is acting strange. At night, it lights up like it normally would. But when I step on the brake, the light goes in the off position. Also, my right blinker indicator lights up in 50% intensity. In addition, when I step on the brake while making a right turn, my right blinkers blinks normally then after 5 seconds, it blinks really fast. I did check the fuses and nothing is blown. What's weird is if the light is blown, why does it still light up when I turn on my head lights?
sounds like wiring to me. when i blew my brake light fuse the brake lights didn't work at all. if a fuse is blown you'd get no response from the lights since the circuit is broken. you probably have a frayed wire or a loose connection somewhere.
hey guys do you know that theres a correct way putting the brake light bulbs, i have leds brake light and when i first put it in the light came on but when i press the brakes it turns off so i took a bulb out turn it 180 degress and put it back in and now it works. Try that before anything take out ur bubls turn it 180 degress and put it back in
Alright, I reseat the fuses under the hood and the cluster right turn signal is working normal now. However, I'm still not getting any lights on the back. I'll have to check the bulbs next...
It is the plug that goes to the taillight wires. I had the exact same problem. Take out your taillights and push and pull gently on the wires on the plug. If any are loose, push it in and using some hot glue, make a big blob to hold all the wires together to the plug. Yes, i said hot glue. This is how its done on most aftermarket taillights so dont dog it till you try it. Do the same to the side from the car and reconnect them. Let us know if this works for you too. Good luck!
Evoguy!123
Jan 26, 2017 10:49 AM
10isace
13
Dec 21, 2009 06:34 PM
boostedwrx
May 22, 2006 04:22 PM
