Cigarette Lighter
Old Nov 27, 2007 | 09:16 AM
Jehuty's Avatar
Cigarette Lighter
My lighter is not giving any power, it won't heat up, charge my phone or anything, I just changed the fuse today, but I was unable to get any juice out of the darn thing. Anyone have any suggestions, I would love to hear some.
Old Nov 27, 2007 | 09:43 AM
cfdfireman1's Avatar
check power to the back of it?
Old Nov 27, 2007 | 11:05 AM
lancerrally45's Avatar
i had the same problem when i bought my car. i took the center console out and found out the ground was unhooked.
Old Nov 27, 2007 | 11:06 AM
robyn402's Avatar
hmm, this just happened to me... but i figure thats what its is a loose or disconnected wire
Old Nov 27, 2007 | 12:35 PM
Jehuty's Avatar
Is there a DIY that I can go to to know how to get to the back and stuff?
Old Nov 27, 2007 | 12:37 PM
atilla's Avatar
it's pretty easy, there are two "screws" on either side of some kick panels on the center console under the dash. inside the ashtray compartment (pull it out) there is one screw. inside the center console storage compartment there are two screws and from there you can remove the entire center console.
Old Nov 27, 2007 | 01:04 PM
Jehuty's Avatar
kk I will try that then
Old Nov 29, 2007 | 08:24 AM
MitsuOZ's Avatar
had the same problem before i had to fix a wire that plugged into the lighter and then that didn't work alone so i also changed the fuse, i hope it all goes well for you
Old Dec 11, 2007 | 07:36 AM
tidal's Avatar
Interesting that you all had, or are having this issue as well. Perhaps if I run my background story somebody might know what the cause of this is: My father bought a little portable heater that I was using to thaw out my windshield wiper fluid nozzles. I plugged it in, let it run about 5 minutes while I was inside getting ready for work. When i came out, it was dead and the plug felt very hot. I checked the fuse and it looks fine. I'm suspecting that one of the wires in the cigarette lighter got burnt out. Any suggestions on where to get a replacement or if i'm barking up the wrong tree?
Old Dec 12, 2007 | 08:54 AM
Jacoby's Avatar
I am having a similar issue..
https://www.evolutionm.net/forums/sh...=1#post5047794
Old Dec 12, 2007 | 01:36 PM
MitsuOZ's Avatar
well if any wire was actually burnt out you can always just cut the wire and solder on a new piece if thats what you think the problem is
Old Apr 5, 2008 | 01:07 PM
jwick76's Avatar
I don't have power when using the cig lighter, but all of my other stuff works when plugged in...and the little light-up ring around the hole doesn't work anymore either. Checked the fuse, it's cool...and I'm assuming the wiring is fine due to everything else working...
I thought LEDs were supposed to last for years?
2rbolag
Sep 23, 2016 08:43 AM
gcevo23
16
Nov 3, 2008 05:43 PM
heSOshAdy
Jul 27, 2006 09:32 AM
Bitnode
Jan 29, 2003 04:35 PM
