Engine Problem..Need help!!!
Old Feb 21, 2008 | 08:52 PM
pr0ph37's Avatar
I'm having the first problem with my lancer and its at 80000 miles. The car wont start. its turning over but it wont catch. i gave it a jump but nothing....i know its not any fuses, i checked them already. im thinking its the plugs, im just avoiding getting it towed to a shop and paying them for something that simple. any help?
Old Feb 21, 2008 | 08:57 PM
ambystom01's Avatar
Why not change the plugs and see if it helps?
Old Feb 21, 2008 | 09:10 PM
pr0ph37's Avatar
i'll be there tomarrow. if after i replace the plugs or i get it checked out and it comes back that im gonna pay alot, ill just trade in for a wrx.
Old Feb 21, 2008 | 09:36 PM
beomoua's Avatar
You need 3 basic things. Spark, Fuel, and compression. First check for spark. next check for fuel (listen for your pump, or if you have been starting it for a while and still nothing check your oil dipstick it should smell like gas.), check for compression which i am pretty sure you have cause it's only got 80K on it.
if your oil smells like gas and you got spark, disable the fuel pump and crank it over a couple times to burn off your gas-soaked plugs. then re-enable your fuel pump and give her a start.
cein88
Lancer Tranny/Drivetrain Tech
Aug 21, 2014 06:14 AM
Boss777
Dec 1, 2013 09:16 AM
Peter Gallup
14
Aug 13, 2012 03:09 PM
monkey_187
15
May 10, 2009 01:05 AM
soontobe
11
Oct 27, 2008 06:17 AM
