ecu bad maybe?
Old Feb 7, 2010, 09:21 AM
lancaholic's Avatar
ecu bad maybe?
here's the deal..did not drive my car yesterday at all..went to start this morning..nothing no lights..no dash lights..nothing but the beeping from the key sensor and dome light..will not even offer to turn over..yes it has a new battery month old red top. But when i turn the head lights on the ecu keeps clicking won,t stop even after you remove the key from the ignition..had to unplug it and plug it back to get it to stop clicking..cleaned all battery terminals..any help would be great.
Old Feb 7, 2010, 09:27 AM
Chele's Avatar
Did you check all your fuses?
Old Feb 7, 2010, 09:52 AM
senate6268's Avatar
Just cause it's a red top doesn't mean that the battery can't go bad. I had a brand new red top go bad on me after just a week. I was convinced that it had to be something else other than the battery because it was an Optima. Have the battery tested.
Old Feb 7, 2010, 11:08 AM
lancaholic's Avatar
Its the battery..got a boost from a friend..fired right up ..taking it back to autozone have them check it. battery was only 2 months old..thanx
Old Feb 7, 2010, 08:58 PM
03lances's Avatar
Check your alternator too to be sure its charging your battery
Old Mar 9, 2010, 01:42 PM
thedarwintheory's Avatar
yeah had this problem yesterday bought new battery and fixed her up but blew the fuse on the terminal for the alternator tho used a foil from a cig pack to link it till i go to auto zone
Old Mar 23, 2010, 02:27 PM
EdT
EdT's Avatar
I don't think its the battery. Has your car just suddenly stop while driving with a CEL on ?
There was a Mitsu TB on the crank shaft sensor. Evidently the casting where the sensor is located(facing engine bay - right side on engine block right behind the thermostat) is badly designed and accumulates sludge over time and cause the sensors to think the crank shaft is out of sequence and stops the car. You have to wait a couple of minutes for the oil to drip off before you can start the car again. They have a newly designed casting($50) that eliminates this problem. In my case the issue showed up just after my warranty expired and I had to fork out cash for it.
Old Apr 27, 2010, 10:53 AM
eusgen's Avatar
Red top batteries have not been getting very good ratings. I have heard from my local Advanced Auto Parts dealer that he has had several (He mentioned at least 5 he knew of)Red Top Optima batteries exchanged within the first year of the warranty. He strongly recommended the Yellow Top and said he had only 1 instance he recalls of it being exchange because of malfunction.
Evo_Goodness
Jan 24, 2017 06:54 AM
fjm9898
Jun 20, 2016 10:12 AM
blowngasket
Jul 1, 2015 09:16 AM
jos
39
Feb 19, 2011 02:55 PM
lilazn64
Lancer Troubleshooting
Feb 23, 2009 10:55 PM
Quick Reply: ecu bad maybe?
