A short in my headlights??
Old Dec 8, 2003 | 05:12 PM
ssr's Avatar
ssr
I just got in my Lancer a noticed that the left light is out. So I turned on the highbeams and it comes on but then it turns the right side off. Anyone have any ideas or help..
Old Dec 8, 2003 | 05:28 PM
Sailorgoon's Avatar
Are you using stock bulbs?
Aftermarket bulbs, especially those made by crappy companies could have defects like this, where one filament is wired to the wrong terminal.
If you're using the stocks, it's time to check all connections and fuses. Then, its dealer time.
Old Dec 8, 2003 | 05:48 PM
Blacksheepdj's Avatar
If you're using Eurolite, that explains it right there.
Old Dec 8, 2003 | 07:29 PM
ssr's Avatar
ssr
I WAS using s#$t bulbs, but I will be putting my stock bulbs back in until I get some sylvania silver star. Thanks for the help
Old Dec 9, 2003 | 05:04 AM
cdyancey's Avatar
putting the original bulbs or known good ones in should fix the problem,
it is a double paralell circuit. each head light is paralell to each other and the high and low fillaments are parallel two each other, you porbably have a low burned out on one side and a high burned out on the other.
very common w/ crappy low end aftermarket bulbs
Old Dec 29, 2003 | 08:27 PM
toe point's Avatar
same thing happend to me, if you try putting on your brights with those crappy aftermarket bulbs they will tend to blow up or burn out... i now have the Vision X 8000k HID conversion kit.. its bad ***. ill try to upload a pic soon.
Old Dec 29, 2003 | 08:38 PM
Archangelite's Avatar
hey i have a question, i bought PIAA bulbs for 80 bucks and just 3 days ago my low went out on the driver side. but ont he package it sez it would last a long time, i think a lifetime??? well, they worked great for about 8 monthes....
Old Dec 29, 2003 | 10:11 PM
ghostrider's Avatar
Yeah, I had the same thing happen to my PIAA Xtreme Whites. Left side low beam as well... And just last night, I had some crappy bulb burn out on me again...
Old Dec 30, 2003 | 09:19 AM
cdyancey's Avatar
contact PIAA and send them back.
also: ATTN! ATTN! when installing new bulbs do not handle glass bulb with hands to ensure you are not leaving any oil on them. this will cause pre-mature (get your mind out of the gutter)
burn out.
Old Dec 30, 2003 | 09:35 AM
yeha i knwo about that, i totally did not touch the bulb, i made sure of it
Old Jan 5, 2004 | 09:22 PM
EcrsEvo's Avatar
i had the same probs with my gay *** eurolites, one goes out, then the other, really bad. now tho, when i got diff lights they dont seem to be pointed the same, like at night if i point towards a wall, i can see the beams are not exactly the same. i tried taking em out and putting em in better but there never the same, anyone got any suggestions?
Old Jan 5, 2004 | 09:25 PM
swhskenr's Avatar
it will do that with any high wattage bulb.. upgrade ya'lls fuses.. i did that and it fixed the problem.. upgrade all light fuses up 5..
i see this happen all the time and i'd like to share the wealth of knowledge that i learned in '01 w/my lancer...
gooov
Jun 13, 2015 04:04 AM
Thahomeboyb
Lancer Troubleshooting
Mar 6, 2014 07:18 PM
byedavidml
Jun 2, 2011 10:23 AM
Ralliart__10
04-06 Lancer Ralliart How To Requests / Questions / Tips
Sep 15, 2010 06:40 PM
mitsuevodriver
Jul 21, 2010 04:51 AM
