Code P0300-Any idea on what could be the cause?
Old Jan 30, 2012 | 02:47 PM
TougeTuned00's Avatar
Car started running rough the other day and i got a code P0300 when i scanned it. Have any of you guys had experience with this and know what it could be. Thank in advance.
BTW: car is a 2003 Lancer OZ Rally with 190k
Old Jan 30, 2012 | 02:51 PM
blkmkIII's Avatar
google it.
Old Jan 30, 2012 | 03:08 PM
CrAnSwIcK's Avatar
random misfire
TROUBLESHOOTING HINTS (The most likely
causes for this code to be set are: )
Ignition system related part(s) failed.
Poor crankshaft position sensor.
Incorrect air/fuel ratio.
Low compression pressure.
Skipping of timing belt teeth.
EGR system and EGR valve failed.
ECM failed. <M/T>
PCM failed. <A/T>
Old Mar 5, 2012 | 06:25 PM
RallyDanny's Avatar
i have 03 rally edition and we have a scanner that told me what cylinder was misifiring and it was cylinder 3 so i swapped the ignition coils an the miss came from the same cylinder and then i threw some new plugs in her and she was good to go running like a champ
Evola0
Jun 14, 2015 09:23 PM
dxlykos0131
May 7, 2014 06:15 AM
8-BallEvo
Aug 3, 2010 07:55 PM
subrwho
Jun 9, 2009 09:26 PM
bhamEVOguy
11
May 4, 2007 01:32 PM
