Random starting issues (2003 Lancer ES)
Old Feb 27, 2017 | 04:02 PM
Chrushev's Avatar
Hi everyone, I have a 2003 Lancer ES (85k miles). This issue started around 60k miles and basically its as follows.
I get in the car, turn the key it cranks, wont start. I stop and lightly tap the accelerator pedal and try again, starts like a charm. This doesnt happen all the time, maybe a few times a week (like one out of 5 to 10 starts). Once car is running it runs like new, no issues whats so ever. Never stalls, never drops RPM.
At first at 60k miles (this is like 6 years ago) I thought maybe its a bad battery, but Ive since replaced the battery (have Interstate battery), and behavior is the same regardless... Ive also replaced Ignition coils and tried Sea Foam.
Its like its something to do with fuel injection or something on start. It always starts on second try after tapping the gas. Does anyone have any ideas? Anyone experience this or knows what can cause this?
Old Feb 27, 2017 | 08:44 PM
4b11slayer's Avatar
Sounds like the fuel pressure regulator is not maintaining pressure for the next start up.
Old Feb 28, 2017 | 10:28 AM
Chrushev's Avatar
Its a stock ES Lancer, no mods, where is the fuel pressure regulator located? I cant seem to find any pictures online.
Does the engine have to be taken apart to replace this part or is it something I can replace myself (is it accessible through the hood?). Also, could it be anything else? And any way to check/test? Like can it be dirty? If so, how can I clean it? How much should one cost? Autozone seems to have one for around $70, does that sound right? Whats a good brand?
Old Feb 28, 2017 | 07:44 PM
4b11slayer's Avatar
Yes you can verify the loss of fuel pressure if you do a fuel pressure test on start when the concern is present.
It could be part of the pump or on the throttle body. Im not familiar with the specific vehicle.
Old Mar 31, 2017 | 09:34 AM
Jdubya555's Avatar
O replaced an lancer oz rally 2.0 2003 with an 2005. But used the throttle body from the 03. O have to crank engine 4 times to start but otherwise runs excellent. Does anyone know if the old throttle body could be the problem thx
Old Mar 31, 2017 | 09:38 AM
realgone2's Avatar
I had somewhat similar problem a while back. Friend of mine cleaned out the throttle body and that cleared it up.
Old Mar 31, 2017 | 09:50 AM
Jdubya555's Avatar
Thank you for the comment. But the car was running good before motor blew from overheating. So you just had the starting problem. Or the whole thing about switching engines
malac0da13
Jun 11, 2012 02:01 PM
jsmits2689
22
Apr 11, 2012 06:15 PM
nginear
Mar 24, 2012 09:59 PM
EvolutionTheory
10
Nov 15, 2009 06:25 AM
kambodianboi
Dec 28, 2008 02:55 AM
