Post all SQUEAK complaints here
Bomb Squad Unit #02
Ok, so since every single week I see a new squeak/rattle/strange noise thread, I'm starting a sticky thread for each. Since most of them are almost impossible to locate, this should consolidate the possibilities and help you guys compare. As for my car, I have all 3 and stopped looking for most of them. It's called a $15k econobox on stiff suspension that gets driven hard. C'est la vie!
Originally Posted by urbanknight
Get some grease, I think lithium grease, because WD-40 will run, get dirty, and fade in no time.
brakes
okay when i first got my car..... the 1st month i was at 6K miles and brakes started to squeak and i didnt mind. i drove lyke dhat till 13k miles.... den started to let cheack my breaks.... and they said dhat it squeaks beacause yah my pads or some shyt neede dchagign and something needed to be bleeded ..... (i didnt knoe wat dhat means) so i was lyke yah ok watever just make it stop..... and the cost have all dhat they had to do was about $350.....and so when they were done they test drove my car and it didnt squeak at all.... but then when i got it and drove about 30 minutes and it started squeaking agen..... so i wont back and ask them did u guyz fix anything because it started squeaking agen and they said its no big deal im lyke ok watever...... and now its bugging me.... i dont knoe anything about cars and shyt... but do you guyz knoe wat will make this squeaking stop
my front right rim squeeks, i've had the brakes done and i am switching the rim today, i am putting the rear tires up front and switching the front to the back...
or is a that not such a good idea?
plus i am debaging the trunk
Bomb Squad Unit #02
moving the rear tires up front and the fronts to the back is fine, it won't hurt anything (actually, that's how you rotate your tires), but it probably won't solve your problem. You might need to have a wheel bearing repacked or replaced. Not too expensive.
I don't think your debadging will help the squeak at all either, but try it anyway
Not really a squeak, but my speedometer cable loves to rattle when the temperature changes. I have pulled the gauge cluster and lubed it. Still rattles. I don't know if anyone else has the same problem. I'm with Urban-15K econobox, you get what you pay for once you start doing more than grocery getting.
replaced it under warranty because it was leaking.
